EGR Valve Location on '05 Gr Cherokee 5.7L - JeepForum.com
post #1 of 8 Old 05-24-2010, 09:02 AM Thread Starter
chadfetter
My Check Engine light came on, and after testing found our the EGR Valve is throwing the codes.
Does anyone know where the EGR Valve is located? Is this an easy job to replace by yourself?
Thanks!
chadfetter is offline
post #2 of 8 Old 05-24-2010, 09:38 AM
Texas WJ
Texas WJ's Avatar
2005 WK
(2)EGR valve
Try this diagram, I think it's the correct one.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #3 of 8 Old 05-25-2010, 09:03 PM
JMorash
2005 WK
super easy. Dealer will charger you 300 plus to swap it out.
48 dollar part online.
It takes three bolts and the pipe removal. bolts are tough to get to
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #4 of 8 Old 07-16-2010, 01:59 PM Thread Starter
chadfetter
Does anyone have this image of where the EGR Valve location is? The image is no longer visible from this original post.
post #5 of 8 Old 07-16-2010, 02:04 PM
JMorash
2005 WK
Remove air box and look under alternator. The egr valve has a long aluminum pipe that you can chase into the intake
2005 WK 5.7L Hemi
JMorash is offline
post #6 of 8 Old 07-16-2010, 03:27 PM
90grandoneer
90grandoneer's Avatar
2006 WK
It's on the passenger side front of the head, as said, below the intake tube above the alternator. There are two bolts holding the EGR tube (to the EGR valve) that goes to the intake and two bolts holding the unit to the cylinder head. The bottom bolt is a bear, but I got mine out without messing with the alternator. Some folks have had to cut the bolt off or move the alternator. When you unbolt the EGR tube, DO NOT remove it, just tie it out of the way. Someone on one of these forums removed it (stuck) and tore the rubber seal that seals it into the intake manifold. This will cost you a trip to the dealer and probably a few day wait for them to get it. When you install the new valve (I paid $54 from AutoZone) I cut about 3/16 in. off the bolt end, chamfered it real well, and then ground down the collar/lip on the bolt head. Next time it'll be a 30 minute job, instead of an hour + 40 this time. How many miles on yours? They seem to go around 40-60K. I had 54K on mine. Hope this helps.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #7 of 8 Old 12-30-2013, 03:26 AM
mario_sb
2005 WK
EGR valve 2005 Grand Cherokee, 4.7L
The EGR valve was surprisingly simple to replacement BUT give yourself at least 2-3 hours.
mario_sb is offline
post #8 of 8 Old 01-02-2014, 01:03 PM
jbarrett
I replaced mine as well - very cheap part from Napa. It is a PITA to change, however. On my '06 5.7, the alternator ended up just being in the way of one of the bolts. Had to remove the resonator box and all the covers and pull one of the polts on the alternator. This allowed me to swing it just enough to get the bolt out of the EGR valve. As Mario said, it's a super easy job, but give yourself 2-3 hours to deal with all the BS that isn't even related to the EGR valve.
jbarrett is offline
LF pic of PCV valve location maxst2 WK Grand Cherokee & XK Commander Forum 7 10-09-2010 10:40 AM
2002 4.7 Cherokee Limited- Fan Relay Location? pzappa ZJ Grand Cherokee Forum 3 01-07-2010 05:50 PM
location of engine computer 2003 g-Cherokee garye5007 ZJ Grand Cherokee Forum 3 11-04-2008 04:23 AM
95 grand cherokee TCU location 96xj4x3 ZJ Grand Cherokee Forum 0 09-14-2006 01:47 AM
2005 Grand Cherokee oil filter location rehitt ZJ Grand Cherokee Forum 1 08-19-2006 04:19 PM
