Easy Exit ON - Keys link to seat position OFF - Keys deprogrammed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Easy Exit ON - Keys link to seat position OFF - Keys deprogrammed
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 08-09-2008, 09:21 AM   #1
Yokumbrook
2007 WK
Minor annoyance, but wondering if anyone knows WHY this happens and if there is an easy fix.
Same setup options in WJ and WK and keys have been de-linked. Works as expected in the WJ. However, in the WK after an easy exit cycle, when you put either key in the ignition, the seat returns to the most recently used driver position. If you tweak the seat in either direction after easy exit position reached, all works as expected and seat position doesn't return to prior driver position. Not too hard to live with except if you are the bigger driver getting in after the skinny one has driven the car.
Yokumbrook
2004 WJ GC Ltd
2007 WK GC Ltd
Yokumbrook is offline   Reply With Quote
