DTC C140F.... What does it mean? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > DTC C140F.... What does it mean?
Savvy Aluminum Gas Tank SkidIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 02-26-2015, 10:42 PM   #1
DB05wkNY
Go Pack!
DB05wkNY's Avatar
2005 WK
So while playing with my new Superchips Flashpaq I decided to check the DTC code list. I have no engine lights or anything telling me something may be wrong. So when I saw this I got a little worried. Here's a screenshot of what the flashpaq had to say... Any input is greatly appreciated.
05 WK 4.7L V8 QTII, RC 2", 1.25" spacers, GG AT2 265/70/17, Bilstein 4600/5100 front/rear, Superchips
SILVER WK CLUB MEMBER #136
DB05wkNY is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 05:15 AM   #2
caulk04
2008 WK
That's the code you get with the N23 recall issue.
It could also be genuine, but most likely it's an erroneous error being caused by a bad N23 flash. Have the dealer do the most recent update to the N23 procedure, make sure they know to follow the instructions to the letter.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 05:49 PM   #3
DB05wkNY
Go Pack!
DB05wkNY's Avatar
2005 WK
Do I have to return to stock with the flashpaq before bringing it to them?
Unread 02-27-2015, 06:41 PM   #4
Kman09JGC
yes if they flash it with the tune in you will lose it. Then you will have pay i think 100 bucks to unlock tuner.
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 07:04 PM   #5
CavallinoRed
2006 WK
You should be able to clear the code with your flashpaq but if N23 related it will come back. C140F is a transfer case alignment error.
Taking it to the dealer to get it re-flashed with the N23 procedure updated 7/29/14 has worked for most and should be no charge but some have had to also have the transfer case actuator replaced as well.
You have to push a bit to get the actuator covered as they are still trained to say there is no connection but with bad circuit boards in the actuator causing the recall in the first place.....
As per Kman09JGC - you should return to stock before you take it in.
CavallinoRed is offline   Reply With Quote Quick reply to this message
