Drivers Side Window Roll Up Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Drivers Side Window Roll Up Problem
Swag Off Road BIG-HIT TJ-YJ Rear BumperAll Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!
Unread 05-20-2015, 05:44 AM   #1
smizzy
2007 WK
My 07 WK drivers side window rolls up to close and then rolls back down. The window some times works and closes properly. I tried resetting the window roll up feature by holding the drivers and passengers buttons in the up position together. Is it a bad master switch or window regulator? Any ideas would be appreciated. Thanks.
Black WK Club # 117
smizzy is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 10:55 AM   #2
ryankokesh
Think this might be the procedure you're looking for:
"a. First, disable (de-normalize) the express-up feature: Drive the glass into the full-up
position by pulling up on the window switch to its first detent (manual mode) and
holding switch until the glass is fully closed.
b. Drive the glass to the full-down position by pushing down on (depress) the window
switch until the window glass is fully open. Do not release the window switch.
Continue to hold the window switch down for 30 seconds after the window glass is
fully open. (Ensure door module is de-normalized by pulling up on the window
switch to the second detent (express mode) and verifying the window does
not go into the express up mode. If the window goes into express mode,
repeat step b. If the window does not go into express mode proceed to next
step.)
c. Reset (normalize) the express-up module for the door window glass in question:
Drive the glass into the full-up position by pulling up on the window switch to its first
detent (manual mode) and holding up on the switch for at least one (1) full second
after the window glass has fully closed.."
From: http://www.jeepsunlimited.com/forums...t-auto-roll-up
ryankokesh is offline   Reply With Quote Quick reply to this message
