Driver's Door Hinge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Driver's Door Hinge
The Cure for your Tie Rod Roll!Steering and more from Ruffstuff!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 02-12-2008, 02:16 PM   #1
2007GrandDiesel
2007 WK
Driver's Door Hinge
I noticed the other day that my WK has started to experience more wind noise than usual on the highway. At first I thought the door wasn't closed all the way, but that wasn't the case. Upon further investigating, I could see that the upper door hinge appears to have become separated from the body. Has anybody else seen this or know if there's a fix on it?
2007GrandDiesel is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 12:11 AM   #2
rbrtcrtr
weak hinged doors
Last week I opened my door on very windy night and now my driverís side door is tweaked. The upper door hinge pulled out about Ĺ inch from post, rubs on fender when opening the door, and sucks wind. On Monday I will get this fixed at body shop. The charge is $700+. Now I will park with vehicle facing the wind so that door will blow close not open. (WK_2007)
rbrtcrtr is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 12:26 AM   #3
jeepgaffer
2006 WK
Yeah the door hinges suck. They are only held in by two bolts each! Its not hard to see how flinging the door open would tweak them without much effort. You can see the hinge flex. A very weak point in the design/engineering/execution of the WK.
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline   Reply With Quote Quick reply to this message
Unread 02-13-2008, 12:48 AM   #4
PropDr
2006 WK
$700.00 plus?
You might try this; open the door fully place a floor jack under the door (not the edge, and a block of wood for protection) lift the door to force the mounting back to its normal position.
After the distorted mounting point is under stress it may require persuasion with a heavy object (a hammer)
06 WK 5.7, No Badges,Gibson CatBack, BWoody CAI, Eibach Springs & upper Ball Joints; F/R ADDCO Bars w/BWoody links; SRT8 Bilsteins; SRT8 Wheels w/ F: 275/50/20, R: 305/20/45 Tires; Passport SRX; 6 Bosch HID's; SRT8 Engine Covers w/ 5.7L badge: Kicker Sys.
PropDr is offline   Reply With Quote Quick reply to this message
Unread 02-14-2008, 12:18 PM   #5
rbrtcrtr
Thanks
Thanks -- I did use a number of persuasive tactics before deciding to have someone with bigger hammers have a shot at this. Appreciate your ideas.
