Driver side Window and door controls - JeepForum.com
post #1 of 15 Old 04-15-2012, 07:45 AM Thread Starter
monterjeep
2006 XK Commander
06 Jeep Commander-
The drivers side window controls are half dead. Only the back window controls work. Front controls, lock, and mirror adjustments are dead.
From what I can find, my door module is bad. I've ruled out the control unit itself. I;ve replaced and have the same result. back windows only work.
Where is this driver side module located? and is the below part what I need?
Thanks in advance!!
06-10 JEEP GRAND CHEROKEE COMMANDER POWER WINDOW DOOR MEMORY MODULE MOPAR OEM
http://compare.ebay.com/like/3903577...Types&var=sbar
monterjeep is offline
post #2 of 15 Old 04-16-2012, 10:23 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
The door module is inside the door.
REMOVAL
1. Disconnect and isolate the negative battery cable.
2. Remove the door trim panel.
3. Disconnect electrical connectors.
4. Remove fasteners and module from vehicle.
I can't access the ebay link from work to see what it is.
JeepCares is online now
post #3 of 15 Old 04-16-2012, 10:47 AM
sebastien
2006 WK
PLEASE PLEASE PLEASE keep me updated on your problem as I share this issue..
sebastien is offline
post #4 of 15 Old 04-16-2012, 11:03 AM Thread Starter
monterjeep
2006 XK Commander
Excellent, thank you. I will report back on how this works out.
post #5 of 15 Old 04-22-2012, 11:58 AM Thread Starter
monterjeep
2006 XK Commander
Fail........
AND........FAIL
Switching the door controls and module not the problem. One step closer to taking it in to the dealer.
Any other ideas?????
post #6 of 15 Old 04-22-2012, 07:43 PM
flexyxj
2009 XK Commander
I'm not sure . Is there a separate relay for the front windows and locks-maybe?
flexyxj is offline
post #7 of 15 Old 04-23-2012, 08:17 AM
sebastien
2006 WK
bump
post #8 of 15 Old 04-23-2012, 08:50 AM Thread Starter
monterjeep
2006 XK Commander
Doesn't appear to be, they all seem to be tied into this one on the door.
post #9 of 15 Old 04-23-2012, 03:39 PM
flexyxj
2009 XK Commander
I've got nothing. I'm just learning about some of these things also.Is there a Body Control Module that controls all the other Modules in different areas of the vehicle?
flexyxj is offline
post #10 of 15 Old 08-04-2014, 05:11 PM
commanderson
Same Issue!
Same issue with 06' Jeep Commander. replaced driver side window control module and still only the left/rear windows goes down. Ideas???
commanderson is offline
post #11 of 15 Old 07-22-2015, 02:06 PM
brian5626
Anyone ever figure this issue out? I'm also having this exact problem on my '06 Commander.
brian5626 is offline
post #12 of 15 Old 07-22-2015, 02:12 PM
329892 - Deactivated
Guest
We had the problem on an '04 Grand. I have 2 friends with the problem on JKUs. The dealer told us to replace the wiring harness. Not just to the door but the entire wiring harness at over $1K. plus install. We sold/traded our Grand in. My friends did the wiring harness which solved their problem.
And yes before selling ours we did all the above trying to solve the problem in our driveway.
329892 - Deactivated is offline
post #13 of 15 Old 07-25-2015, 07:38 AM
brian5626
Thanks for the response. I was hoping someone may be able to give me the exact wire that was causing the problem and I could just splice a new one in. I may be stuck replacing the entire harness. I'm tempted to try a junk yard first. Thanks again.
post #14 of 15 Old 07-25-2015, 08:05 AM
tapenick
I had a similar problem that was caused by a broken wire in the harness. I can't tell you which wire it might be but if you pull the rubber "conduit" (between the door and body) back you'll probably find one or more broken wires. Sometimes you have to look close because the loose end of the wire will be stuck in the conduit. Can easily be spliced back together. I recommend checking the harnesses in the other doors and I think it works as a system and broken / flaky wires there will cause intermittent problems. Hope this helps!
Tom
2000 TJ
2002 KJ
2007 XK
tapenick is offline
post #15 of 15 Old 07-26-2015, 10:32 PM
brian5626
Tom, thank you for the response as well. I checked extensively for a broken wire at the door frame, but I was mainly looking for a wire that was still barely attached by the sheath. I will take a closer look and see if it's broken completely and now hidden in the door. It's worth a shot. Take care, Brian.
HELP!!! Driver side window won't go up WBowie ZJ Grand Cherokee Forum 17 08-08-2009 01:57 PM
'04 4.7HO Problem with Driver's Side Window Controls and Locks CEaston140001 ZJ Grand Cherokee Forum 3 06-01-2009 07:18 AM
Driver side window doesn't go up Othoni ZJ Grand Cherokee Forum 4 11-27-2006 01:28 PM
Driver Side Window.... CBlakeNS ZJ Grand Cherokee Forum 10 02-20-2006 05:33 PM
How to get to driver side window? Graphic ZJ Grand Cherokee Forum 7 08-22-2005 09:04 PM
