Driver door seal - JeepForum.com
post #1 of 10 Old 03-15-2012, 05:14 PM Thread Starter
PeterF
2006 WK
Driver door seal
Does anybody know where I can get this door seal? Not the seal on the actual door, but on the body.
PeterF is offline
post #2 of 10 Old 03-15-2012, 05:31 PM
colinzj
2006 WK
It's a dealer-only part.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 10 Old 03-15-2012, 05:32 PM
cmdrjim
2006 XK Commander
Attachment 364117
Mine did that as well. You could use black silicone to mend it. Just don't close the door till it cures. Liquid Black Tape works as well.
06 Red Jeep Commander 3.7L V6 "Manual QT2", and many more upgrades
cmdrjim is offline
post #4 of 10 Old 03-15-2012, 05:50 PM
gradeigh1
2005 WK
Its forty something bucks on justforjeeps.com. I did mine before the winter. I got the part number and did a search. Got it for around thity bucks shipped.
gradeigh1 is offline
post #5 of 10 Old 03-15-2012, 05:56 PM
t3kmitch
2005 WK
Mine looks the same. I forgot I was going to get the dealer to replace it when I bought it. Oops. Is there any reason to replace it other than if water leaks or wind noise?
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #6 of 10 Old 03-16-2012, 09:24 AM
marka2k
2006 WK
Mine did this as well, in the winter I could feel cold air entering the cabin while driving from that area. $40 and 10m and it was fixed
marka2k is offline
post #7 of 10 Old 03-16-2012, 10:23 AM
S197GT
2005 WK
we bought our jeep used and it has the same thing. i wondered what the heck the previous owner did to cause it. apparently this is just normal wear/tear?
thanks for the heads up:
http://www.justforjeeps.com/05wkfrdo.html
S197GT is offline
post #8 of 10 Old 03-16-2012, 11:25 AM
pavelhen
2005 WK
I bought mine used and thought the same exact thing. I assumed it was wear from the previous owner entering exiting but have yet to touch it myself so I was curious.
Glad to see others have the exact same issue. Thanks for the link to just for jeeps.
pavelhen is offline
post #9 of 10 Old 03-16-2012, 12:09 PM
No4x4Yet
Weather stripping is pretty generic no? Quadratec just started stock weather stripping for the XJ, might be able to use that?
No4x4Yet is offline
post #10 of 10 Old 03-16-2012, 09:56 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
In most cases, within the same manufacturer, yes or close enough.
Those seals also tend to shrink and come away from the corners, what I did on my car when they shrank (or even to replace a section) was to get a seal from the wreckers and cut the length I needed (actually did all 4 drs) inserted the piece between the 2 ends and used a super glue to join the pieces. On the corners, you want to pinch the seal narrowing the gap of the seal part that fits over the body edge. Just replacing a section will leave you seeing another seem so if it's cheap enough, just get a new one. The seals are not glued in, it's just a snug fit.
YB Normyl is offline
