Which Drive system do I have? - JeepForum.com
post #1 of 4 Old 04-13-2013, 04:14 PM Thread Starter
nocojeep
1990 XJ Cherokee
I just bough my WK last Friday, it's a 2006 Laredo 4.7. I am new to this forum and still trying to figure out exactly how it works. Quick question I have though is how do I find out what drive system I have ? (As is quadra drive I or II) I have no idea. Like i said it is a 2006 Laredo 4.7 and it does have the low range option lever thing next to the transmission shifter. Thanks!
nocojeep is offline
post #2 of 4 Old 04-13-2013, 04:31 PM
LJS8510
LJS8510's Avatar
2015 WK
Congratulations
you will find out a lot of info here
http://www.wkjeeps.com/kmenu.htm
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #3 of 4 Old 04-13-2013, 05:07 PM
yzjwk
2005 WK
chances are you have neither system. quadra drive 1 was never available in the wk ( 1999-2004 wj only) and you would have probably seen the quadra drive II emblem under the 4Low T handle if you had it , so i'll say you have the only other option that is quadra trac II . But just incase , you can look at your rear differential bolts 10 bolts = quadra trac II and 14 = quadra drive II.
welcome
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 4 Old 04-13-2013, 06:52 PM
jjt250
2007 WK
welcome
12 bolts for QDII, not 14. Sounds like you have QTII though. Welcome!
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
