Dreaded wet floor problem 05 LTD - JeepForum.com
post #1 of 8 Old 07-16-2007, 08:16 AM Thread Starter
madmarchhare
Well, the 98 did it, the 99 did it, now the 05 is doing it...
The floor on the passenger side is wet !!
This time though , there is trace of water comming out of the cover for the grab handle (or oh sh*% handle as we all know it).
Any idea where this water is comming from, before I end up pulling the roof liner down?
madmarchhare is offline
post #2 of 8 Old 07-16-2007, 08:56 AM
T-Rated
T-Rated's Avatar
Has it been raining? Car wash? Do you have a sunroof?
I'm just trying to figure out if it's outside water getting in, or if it's something else.
Regardless, there is a TSB about this:
http://www.wkjeeps.com/tsb/tsb_wk_2305004.pdf
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #3 of 8 Old 07-16-2007, 10:16 AM Thread Starter
madmarchhare
yes.
Raining hard and a sunroof
post #4 of 8 Old 07-16-2007, 10:56 AM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Definately the sunroof drains. That TSB will cover it.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #5 of 8 Old 07-26-2007, 04:10 PM
06limited4.7
Wet passenger floor
I dont have a sunroof and they have had my 06 for two days now trying to find the problem. It's been raining alot here and I really noticed it after I washed it.
06limited4.7 is offline
post #6 of 8 Old 07-26-2007, 04:23 PM
merlinTec
merlinTec's Avatar
Hi
There are a number of TSB’s for this fault
2305004 is for the sunroof drain tubes
2304006 is for the sunroof glass not flush to roof
2305005 superseded by 2302606 is for door secondary seal.
Any or all of these could be your fault
All the best
Regards,
Merlin
merlinTec is offline
post #7 of 8 Old 07-26-2007, 07:51 PM
HurriJeff
2013 WK
Let me start by saying I was only at the carwash because of strict water restrictions !!
That being said, I had this problem a few weeks ago. Was caused by an over eager blower at the local drive thru carwash. There are two blower nozzles that point directly down at the sun roof. They push the sunroof down quite a bit (about 1/4 inch) while drying the car. On a day I had had the car washed it rained heavily and I got water inside. Dripping from the passenger side grab handle and from the homelink buttons. I think that the glass had just stuck in the "pushed down" position. Once I opened and closed it, it seemed fine and has not leaked again since.
Keep us posted madmarchhare
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #8 of 8 Old 07-27-2007, 02:24 AM
janeandpault
Same problem with 96 GC the dealer found some screws holding thr trim under the rubber door seal needed resealing. Hope tis helps
janeandpault is offline
The dreaded engine randomly shuts off while driving problem. Ved ZJ Grand Cherokee Forum 21 06-05-2016 12:13 PM
strange problem with HVAC control. off/top/floor/mix/defrost selector fivespeedsteed ZJ Grand Cherokee Forum 2 05-10-2009 03:04 PM
heating/cooling- vent/floor problem. spros95jeep ZJ Grand Cherokee Forum 2 09-19-2006 05:09 PM
the dreaded question NYSCARLETKNIGHT ZJ Grand Cherokee Forum 6 07-11-2006 02:27 PM
The Dreaded Tranny Q. BlaineWasHere ZJ Grand Cherokee Forum 11 01-01-2005 10:40 AM
