Drain Plug Will Not Drain - JeepForum.com
post #1 of 10 Old 05-04-2012, 12:19 PM Thread Starter
deandec
2005 JGC 4.7L engine. (Not the jeep in profile)
First change of coolant.
I was able to loosen the drain plug with a pliers and then turn the plug handle about 180 degrees.
I got a steady thin stream of coolant which slowed to a drip. Loosing the radiator cap and overflow cap did very little to fix the problem. I twisted and turned the plug many times with no better result.
Total drained was about 1 gallon of fluid. The overflow tank did not drain at all. I added back 1 gallon of water, and the system is bled and full.
So, how is that drain plug supposed to work to drain 12.75 quarts of coolant?
Any help is appreciated
Dean
99 and 05 JGC 4.7L
deandec is offline
post #2 of 10 Old 05-04-2012, 02:28 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
So, how is that drain plug supposed to work to drain 12.75 quarts of coolant? Any help is appreciated
Gravity and pressure, i.e.- adding more water or a garden hose in the radiator cap/fill. IIRC you want to have the motor running while you do this as well.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 10 Old 05-04-2012, 04:40 PM Thread Starter
deandec
Thank you for the quick reply.
So in effect the plug is designed to force a flush every coolant change (100,000 miles or 5 years) ?
How will the overflow tank then drain from the system?
Dean
99 and 05 JGC 4.7L
deandec is offline
post #4 of 10 Old 05-04-2012, 04:47 PM
oilverland
2008 WK
You'll want to have a look at the service manual - see:
http://www.jeepforum.com/forum/f67/0...anual-1311193/
2008 Overland Diesel QDII, Bilsteins, Stillen rotors and pads, 156,000 miles as of Nov '16.
oilverland is offline
post #5 of 10 Old 05-04-2012, 05:21 PM Thread Starter
deandec
Thank you for the service manual reference, that will come in handy in the future.
It also answered the question of how to drain the overflow tank, but unfortunately the proscribed procedure did not work.
So, I am still looking for help on how to get the thing draining more aggressively since the above manual does not discuss the drain plug.
A replacement plug at car parts.com is described as "push in and twist drain plug". That would imply the plug should pull out some distance.
I have not been able to pull out the plug so far.
I will try again.
Dean
99 and 05 JGC 4.7L
deandec is offline
post #6 of 10 Old 05-04-2012, 05:46 PM
colinzj
2006 WK
It's possible you had sediment collect around the drain and restrict the flow. You should be able to drain the whole shebang using the draincock.
If you run into a problem, pulling hoses is usually the answer. She'll drain real nice (and real sloppy) with no bottom hose. You can similarly drain the overflow by pulling its hose off the radiator neck.
Going the yanking hoses route, you will want a very large bucket, and you may want something to protect the floor.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #7 of 10 Old 05-04-2012, 08:09 PM Thread Starter
deandec
Colinzi, you are most likely correct. Tonight I have been able to drain the overflow tank and am now getting a solid stream of coolant. I had to work the handle open and closed several times to get the steady but thin stream. But it will take about 2 hrs for it to drain at this rate.
I tried to clear up the pathway with a paper clip, but having seen a picture of the replacement drain plug, it looks as though there is no straight pathway.
I will see how far this will take the project. Then do the lower hose trick for the remainder.
Thanks to all who responded. I will report back the result.
Dean
99 and 05 JGC 4.7L
deandec is offline
post #8 of 10 Old 05-05-2012, 10:56 AM Thread Starter
deandec
No Coolant draining
Well, I am not the sharpest tack in the pail, but I am confused........
I drained about 5 quarts of coolant from the drain plug.
I removed the lower hose and got nothing.
The overflow tank is empty.
I briefly ran the engine to see if any additional pumped out. Nope.
I am supposed to see a replacement volume of about 14.75 quarts. Drained only 5 quarts.
(Note: My drain plug now works after draining the radiator and blowing 20 psi into the drain plug hole.)
Since I am replacing the Chrysler HOAT with another HOAT, I would like to get all the old coolant out. So will flush the system a couple of times (one gallon drained per time).
On my Cummins C8.3L I get 25 gallons with no effort at all so I think I know the procedure.
Why am I only draining 1 gallon at a time instead of about 3 gallons?
Dean
99 and 05 JGC 4.7L
deandec is offline
post #9 of 10 Old 05-05-2012, 11:10 AM
p3busman
Is 14.75 what you are supposed to get out or is that the total cooling system capacity? There will be coolant trapped in the engine, heater core, etc.
p3busman is offline
post #10 of 10 Old 05-05-2012, 11:32 AM Thread Starter
deandec
Ok, the trapped stuff I will have to remove through another few cycles I guess.
Just surprised that 60% of the coolant is in the engine. I guess radiators are more efficient these days.
Thanks for the assist.
Dean
99 and 05 JGC 4.7L
deandec is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
4.0 Oil Drain Plug todd4198 ZJ Grand Cherokee Forum 8 12-29-2011 02:26 PM
249 Hex Drain Plug fr33zypop ZJ Grand Cherokee Forum 1 08-27-2011 06:10 AM
35C Drain Plug FlipFlop425 ZJ Grand Cherokee Forum 15 09-13-2007 01:19 PM
transmission pan with drain plug Mussel Doc ZJ Grand Cherokee Forum 3 08-27-2004 01:28 PM
