DPF Delete - JeepForum.com
post #1 of 3 Old 10-20-2013, 11:39 AM Thread Starter
Nookie
2015 WK
DPF Delete
Lots of Info available already on a DPF delete & good stuff!!, but wanted to throw a question out there as to the software part.
I'm not after more performance, just the DPF delete.
Anyone ever tried to trick the ECU with resistors vs software ? like the swirl motor trick ?, anyone care to guess if it's possible to put resistors in place of the two sensors with a value that does not trigger a regen ?
would the system look for pressure diff over time ?
-G
2014 WK2 Diesel
Nookie is offline
post #2 of 3 Old 10-20-2013, 06:06 PM
MBDiesel
2015 WK
Doubt it. The swirl motor circuit basically just checks for motor continuity while the DPF pressure sensors correlate with engine load. I bet a constant value would confuse the computer when the indicated pressures didn't change when the engine was under high load. Better off with GDE, IMO.
MBDiesel is offline
post #3 of 3 Old 10-21-2013, 08:50 AM
tnadanzig
tnadanzig's Avatar
2007 WK
A simple resistor would not be possible on the DPF pressure sensor. The ECM looks for a range of values and you would need to create a circuit board to simulate those values. Also, the vehicle would probably go into regen every 1000 miles or so because the stock software requires a regen after so many miles even is the DPF isn't plugged. In diagnostic software you can pull up miles since last regen and it will tell you. With DPF delete tuning it just list zero because the maps have been modified to eliminate that function. Unfortunately the only way is through tuning.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
