Double Din Radio install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Double Din Radio install
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAdvance Adapters SYE Kits
Unread 08-02-2014, 05:27 PM   #1
Jaashua
2005 WK
I wanna make sure I order everything I need at once. Any tips or ideas are appreciated. I currently have the factory radio. I'm getting a Nav benzel from a friend. What else do I need. I have the factory amp in my Jeep and an aftermarket subwoofer amp. I want the steering wheel buttons to work.
So what I think I need?
http://www.amazon.com/gp/product/B00...productDetails
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
And obviously the radio of my choice. Anything else?
Jaashua is offline   Reply With Quote
Unread 08-02-2014, 08:58 PM   #2
B2LL2F
You will probably need the bezel- big dome sort of piece that replaces the bezel for the odd shaped stock radio
B2LL2F is offline   Reply With Quote
Unread 08-02-2014, 09:13 PM   #3
Jaashua
2005 WK
Already have one on the way.
Unread 08-02-2014, 10:38 PM   #4
B2LL2F
i also needed an antenna adaptor... but im in Aus so not sure if you will
Unread 08-03-2014, 08:45 AM   #5
mrjaydeeone
2007 WK
B2LL2F is correct. I just installed in my 07 grand cherokee and needed antenna adapter like this http://www.amazon.com/Metra-40-CR10-...ntenna+adapter
Current 2007 WK Graystone Pearl V8 4.7 limited fully loaded. Current mods Escort 9500 IX tapped into rearview mirror and mounted under mirror with bicycle reflector bracket. 6K HIDs in Lows and 3K HIDs in Fogs
mrjaydeeone is offline   Reply With Quote
Unread 08-07-2014, 01:02 PM   #6
Jaashua
2005 WK
What radio harness did you guys go with? I'm getting conflicting reports of what actually works with ours.
Unread 08-07-2014, 01:08 PM   #7
rockrunner02
2005 WK
A harness comes with the PAC adapter. You will need an additional adapter to allow everything to talk to your factory amp. I believe Metra makes one, but most people don't have much luck with it. Normally without that adapter you will lose your sub (which you won't have an issue with) and any fading ability. I went initially went this route but could never get the system to work properly so I ditched it all for a Mygig RER and couldn't be happier. Looks factory and everything works as it should. Best part is that it was installed in about an hour.
99 wrangler with stuff: Sold
00 XJ- stock: Sold
98 wrangler: 4" lift 33's Dodge V8 swap: Sold
rockrunner02 is offline   Reply With Quote
Unread 08-07-2014, 03:20 PM   #8
Jaashua
2005 WK
Well now this seems annoying. One of the reason I want an after market is for more control of the system. My sub is way to overpowering some days.
Unread 08-07-2014, 03:50 PM   #9
Jaashua
2005 WK
Also the Pac claims it retains the factory amp.
Unread 08-07-2014, 03:54 PM   #10
JeepGC05
2005 WK
http://www.ebay.com/itm/301213507748
This is the harness that I have been told to get it retain steering control and for amp or mom amp.
JeepGC05 is offline   Reply With Quote
Unread 08-07-2014, 05:21 PM   #11
rockrunner02
2005 WK
The PAC module I had retained the SWC but did not 'talk' with the stock BA amp. I had no sub and no equalizer settings. There's a bunch of info on another site, people either bypassing the amp or running an adapter that would integrate it. Most would bypass it and do a fully aftermarket system as it would be easier than integrating the Canbus system. But then again, I'm no audio guru by any means.
00 XJ- stock: Sold
Unread 08-08-2014, 09:56 AM   #12
Jaashua
2005 WK
Yeah that's the harness my friend recommended. Although he said I need another Pac product for the steering wheels.
Unread 08-08-2014, 10:29 AM   #13
colinzj
2006 WK
What stereo are you looking at? If it's new enough to support the iDatalink Maestro, using that instead of a PAC or Metra would retain the basic equalizer controls, fade, and the steering wheel controls.
If you're looking at a Pioneer, they claim to support the iDatalink, but it's the same vaporware BS they always pull. That firmware doesn't exist yet. Kind of like the "early summer" CarPlay update, or any other firmware update Pioneer has ever said was coming. You'd have steering wheel controls in the mean time, but the fade and equalizer would be as equally broken as anything else unless/until Pioneer makes good.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Unread 08-08-2014, 08:00 PM   #14
Jaashua
2005 WK
Thanks I'll look into it. Haven't picked out a radio yet.
