Donuts=no power steering - JeepForum.com
post #1 of 10 Old 02-14-2014, 04:28 PM Thread Starter
StormTrooper07
Help needed! Saw an open parking lot full of snow and couldn't help myself. However, when I got done I heard a whining noise and soon realized I had no power steering. I believe the problem to be the pump, am I on the right track?
Thanks in advance!
StormTrooper07 is offline
post #2 of 10 Old 02-14-2014, 05:02 PM
08hemi
2008 WK
The belt didn't pop off did it?
08hemi is offline
post #3 of 10 Old 02-14-2014, 05:17 PM
Jeepforthewin
2010 JK Wrangler
I'd check the belt first also and look for signs of a leak.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 10 Old 02-14-2014, 05:46 PM Thread Starter
StormTrooper07
Belt appears to be fine...fluid was low so I put some in, but I still have the whining noise and no power steering..
post #5 of 10 Old 02-14-2014, 06:25 PM
BoraBora
2015 JK Wrangler
Exact same thing happened to my friends WK last night...belt look fine in his too...
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #6 of 10 Old 02-14-2014, 10:09 PM
caulk04
2008 WK
Are you one of those people who holds the wheel all the way turned making the rack force against the steering stops? That's really hard on the steering gear...
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #7 of 10 Old 02-14-2014, 10:39 PM
yzjwk
2005 WK
Thanks in advance!
If you have a HEMI or CRD , then the power steering pump is used for the hydraulic cooling fan as well . You could have knocked the bottom hydraulic hose off somehow . Make sure you got fluid in there or you could start overheating too .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 10 Old 02-15-2014, 12:07 AM
xSoFx
1987 XJ Cherokee
As stated, find out where that fluid went. If you have no leaks, feel free to purchase a new power steering pump before you overheat your engine.
xSoFx is offline
post #9 of 10 Old 02-15-2014, 04:41 AM
imann
2006 WK
If you have the hydraulic system ,anything from your fan to FCM could cause the pump to strain and whine......I literally just replaced my entire system from the fan to the pump to the **** and all sensors etc......it was a headache....if yzjwk chimes in you may get a precise answer as he helped diagnose my problems dwn to the fcm
06WK slvr#107-hemi-QDII-3.5 Mopar-bilsteins-JBA frnt discos-275/70r17 BFG KM2 MTs-BT cc-
Airraid CAI-Magnaflow exh-super chip prgmr-9k MM winch in custom frnt bumper wth D-rng's
4x grd frnt/rear skids & rear sliders w/D-rng's-BT shrty ant-stillen crs drlld x4-pinch weld mod
imann is offline
post #10 of 10 Old 02-15-2014, 11:22 AM
Drew
2007 WK
especially when your romping on it doing donuts in the snow....
2007 WK 3.7
Drew is offline
