Doing my own maintenence, and going premium - JeepForum.com
post #1 of 9 Old 08-27-2007, 10:14 PM Thread Starter
AnalogDog
I had an evil co-worker give me a lecture on synthetic oils, Kendall GT1 and Amsoil, and I read up on them on the web, and now I am off to premium filters and such. Such is my life, if its not one thing, its a hundred.
I have a 3.7 2006 WK Laredo that I am going to wrap up the year since I bought it with 21,000 miles. According to the Recreational Oil Changers, that means 7 oil changes, or if I go by the book, 3.5 oil changes.
Humm, could I get it down to 2? Or none? Anybody doing the Amsoil thing? Testing oil every 16,000, and not replacing it?
But more mundane, who's using synthetic oil? And what filter system are you using? What's your change rate? 3k? 5k? 10k? Never? Is anyone using a premium filter system? Fram Extreme Duty, and the like.
But anyway, I am opening myself up to doing my own maintenence after about 15 years of having Jiffy Lube do it, and I want to see what's good, and not so good out there.
Rob
AnalogDog is offline
post #2 of 9 Old 08-27-2007, 10:22 PM
Scottina06
Scottina06's Avatar
2006 WK
I am using Mobil1 5w-30 with the K&N oil filters
Scottina06 is offline
post #3 of 9 Old 08-28-2007, 07:17 AM
garsarno
Been using Mobil 1 on our '07 Hemi GC since 1,000 miles and changing every 4,000 miles at local Gulf gas station with Jeep filter. No problems with oil related issues since mid 80s on all of my cars.
garsarno is offline
post #4 of 9 Old 08-28-2007, 08:50 AM
T-Rated
T-Rated's Avatar
I just started with Royal Purple and the K&N filter. I plan on going 5k, then doing an oil analysis with Blackstone Labs. Based on the results, I'll decide if I can up the interval a bit. Though I wouldn't mind every 5k just for peace of mind.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #5 of 9 Old 08-28-2007, 02:00 PM
jeep_on
Im my WJ Im running 5W30 AMSOil and an over-sized K&N filter (engine now holds seven quarts of oil) and change it every 6,000 miles. In my Dodge RAM I run AMSOil 15W40 heavy duty diesel oil with a Fleetguard filter, change it every 15,000 miles.
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #6 of 9 Old 08-28-2007, 08:31 PM
Intrepidjeep
Intrepidjeep's Avatar
I run Mobil-1 5W30 and the oversized oil filter -- the filter that you'd use if you had an old Dodge or Chrysler with a 440 under the hood Fits the same but has a longer body for more capacity and less restriction through the filter.
I change oil around every 7000-9000 miles.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #7 of 9 Old 08-28-2007, 08:31 PM
HurriJeff
2013 WK
I only use 5W-20 as reccomended by Jeep for the 5.7 Hemi. I only use Mobile 1 in all of my personal engines. And on my Jeep , Purolator PUR1 oil filter.. the purple/blue one. I have read that it has more filter surface area, better quality materials inside and a better casing. Additionally its synthetic filter media and not cellulose/paper.
Here are a few links that will helpyou learn more about oil filters.
http://minimopar.knizefamily.net/oilfilterstudy.html
http://synlube.com/oilfilters.htm
Good Luck !
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #8 of 9 Old 08-29-2007, 04:51 PM
TMJeep
In my '05 Grand Cherokee I use Amsoil XL 5W30 which is rated for 7,500 miles or 6months with the Wix filter and I change every 6,000 miles. In my 98 Wrangler I use 10W30 which is rated for 25,000 miles or 1 year and use the Ea filter by Amsoil and that is also rated for 25,000 miles or 1 year and I change that about once a year.
98 Sport TJ 4.0L
Chile Pepper Red with Black Dual Tops
Trueflow Air Filter
31" BFG A/T
Cibies headlamps, plus 30 bulbs
other than that pretty much stock for now
TMJeep is offline
post #9 of 9 Old 09-10-2007, 10:28 PM
054.7JGC
2010 WK
i use only amsoil
hi
i have used mobil 1 up until i returned from iraq in 2004 and then i went totally to amsoil synthtetics in my vehicles.
i have an 07 JGC 4x2 hemi with mds so i have to use 5w-20 xlm (extended life motor) oil. with this i use the amsoil ea filter. i am goint th full 7500 mile enterval.
i also have amsoil synthetic transmission fluid and amsoil 74w-140 differential fluid
as well..amsoil front to rear.
amsoil is the first to make fully synthetics and the best. mobil
054.7JGC is offline
Maintenence Recommendations kamonjj ZJ Grand Cherokee Forum 7 01-29-2010 04:08 PM
Maintenence ? tufmar ZJ Grand Cherokee Forum 11 12-13-2006 06:33 PM
Does my 98 5.9 really need premium? white5nine ZJ Grand Cherokee Forum 15 01-16-2005 03:16 PM
simple maintenence question K-Pax ZJ Grand Cherokee Forum 2 11-04-2004 08:42 PM
Perform Maintenence Message 99JGCLTD ZJ Grand Cherokee Forum 1 09-05-2002 08:54 AM
