does anyone know how to take the metal under the radio off? - JeepForum.com
post #1 of 2 Old 09-07-2007, 09:40 AM Thread Starter
jmack549
2006 WK
apparently i have to tap into the power line going to my lighters, since i cant find a ignition wire while hooking up my aftermarket radio. does anyone know how to remove this metal piece? i feel like i am about to break it while pulling on it. thanks in advance!
jmack549 is offline
post #2 of 2 Old 09-07-2007, 10:09 AM
merlinTec
merlinTec's Avatar
1. Using a trim stick C-4755 or equivalent, separate the radio bezel, if equipped.
2. Using a trim stick C-4755 or equivalent, separate the radio hood bezel.
3. Using a trim stick C-4755 or equivalent, remove the shifter bezel ring.
4. Using a trim stick C-4755 or equivalent, remove the shifter bezel.
5. Remove the screw inside the lower storage bin, if equipped.
6. Using a trim stick C-4755 or equivalent, separate the clips and the center bezel.
7. Disconnect the electrical connectors.
UK Chrysler Jeep Master Tec.
merlinTec is offline
metal on metal scraping sound chrisstromberg ZJ Grand Cherokee Forum 13 05-23-2009 04:17 PM
Metal on Metal "clanking" staggwj ZJ Grand Cherokee Forum 1 05-17-2009 05:42 PM
WJ with horrible metal on metal suspension sounds Clockwork15 ZJ Grand Cherokee Forum 2 01-24-2009 03:05 PM
metal squeaking on metal? sound from front Dillonzj ZJ Grand Cherokee Forum 3 11-28-2008 12:08 AM
metal on metal sound in rear brammabull69 ZJ Grand Cherokee Forum 7 05-21-2007 10:05 PM
