Do you need to disengage transfer case into neutral for towing?? - JeepForum.com
post #1 of 6 Old 10-07-2013, 03:58 PM Thread Starter
va7cid
2008 WK
I am a little confused as I was going thru the manual and came across the recreational towing section indicating that you have to unlock the transfer case into neutral, is that true or not? Thank you in advance.
va7cid is offline
post #2 of 6 Old 10-07-2013, 04:11 PM
colinzj
2006 WK
If you're flat-towing the Jeep behind another vehicle (or using a dolly), the transfer case needs to be in neutral.
The only time it doesn't need to be in neutral is if the Jeep has no wheels on the ground.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 6 Old 10-07-2013, 04:14 PM
sickchilly
2010 WK
If you flat tow your rig behind another, you must put the transfer case in neutral.
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #4 of 6 Old 10-07-2013, 04:15 PM
jay-h
Yes, that's very much a feature. Many cars cannot be safey flat towed.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 6 Old 10-07-2013, 08:59 PM Thread Starter
va7cid
2008 WK
Thanks for verifying the info, I wish they would have write the manual more in layman term. Instead of trying to confuse the heck out of the reader. Thanks again
va7cid is offline
post #6 of 6 Old 10-08-2013, 08:13 AM
tjkj2002
2002 KJ Liberty
4wd must have t-case in "N" and the trans in Park,very important that the trans is in park otherwise you will melt down the trans and t-case.
2wd you must remove the rear driveshaft.
If you spin the trans without the engine running,IE the trans pump working, it creates a lot of heat which will melt the trans/t-case.Seen it happen many times.
tjkj2002 is offline
