Do you guys take out your oil separator when your WK is serviced?
#1 | |
I installed my oil separator a month ago, so far it seems to work well (once I modified the system for the extreme heat, leaks and engine vibration).
I had planned to remove my setup when taking the WK in for service since it takes about 15 min to remove and 15 min to install. I didn't want the service technician to say my setup voids my warranty, but maybe I will leave it in. Has anyone else with an oil separator setup been questioned by their dealer when the deal they take their CRD in for service?
2008 WK "S" Limited bright metallic silver, 5 speed W5J400 transmission, June 18/2008 build, 213RE rear differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, 3.0L CRD. |
#2 |
NOPE.... been to 2 different dealers 3 times, never had an issue
2007 GC LTD CRD 2x4.........For towing... 1985 Mustang SVO 2.7t......In progress |
#3 |
Since this actually saves them work down the line I doubt they'd give you any trouble over it. If they do it's probably not a dealership that you would want working on your vehicle.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
