Do any of the non-CRD owners have a stock "metal" skid plate under the transmission? - JeepForum.com
post #1 of 16 Old 08-16-2013, 11:06 AM Thread Starter
suzieque
2008 WK
the stock CRD seems to have a flimsy/weak plastic dust shield under the transmission pan. I removed it and I can post a picture of it.
do any of you non-CRD owners have a stock metal skid plate under the transmission pan (between the fuel tank and engine)? or do you have to buy an aftermarket metal skid plate?
I have stock metal skid plates under the engine and under the fuel tank.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 16 Old 08-16-2013, 11:20 AM
Anon155
2005 WK
It all depends if your jeep came with the offroad package from the factory or not. You got 3 skid plates with that add on package (front, transfer case, and gas tank). You can buy the steel transfer case skid plate that the non-CRD jeeps use from the dealer or online. It attaches to the gas tank skid and the metal cross member that's directly under the front seats. I can't say if it would work for you guys or not though.
Here's a link: http://www.justforjeeps.com/skidplates7.html
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #3 of 16 Old 08-16-2013, 11:31 AM Thread Starter
suzieque
2008 WK
Originally Posted by Anon155 View Post
what's interesting about the picture on this website is that they do not show a skid plate under the transmission pan either.
suzieque is offline
post #4 of 16 Old 08-16-2013, 11:58 AM
Anon155
2005 WK
Oops. Sorry, didn't see you wrote transmission pan the first time. Jeep doesn't make a factory one for that. 4xguard makes a belly skid that would go between the front skid suspension skid and the transfer case skid. Their newest design would completely cover it. I know it works on a CRD because the owner Marlin said that's what they used to mock it off of.
Anon155 is offline
post #5 of 16 Old 08-16-2013, 05:15 PM
BAH101
2008 WK
The 4X Guard will fit the CRD no problem. I have the older version, it covers the DPF and tranny. The left side is open, but that should be no problem, the new cover slants up on both sides. The plate hangs about 3/4 or so inches lower than the engine plate as it was designed to fit the Cats for the gas engines.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #6 of 16 Old 08-17-2013, 02:35 PM
TurboDiesel
2008 WK
i dont have any steel skids
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #7 of 16 Old 08-18-2013, 10:34 AM
ajxj9197
2009 WK
I just noticed today I have skids all on the bottom. Added bonus to the new purchase they are pretty beefy too for factory.
I need to update my username to reflect the new jeep -.-
ajxj9197 is offline
post #8 of 16 Old 08-18-2013, 12:40 PM Thread Starter
suzieque
2008 WK
If you geta chance, could you take a photo of the skid protecting the transmission pan? It would be near the catalytic converter, but I'm guessing the catalytic converter is not covered.
suzieque is offline
post #9 of 16 Old 08-18-2013, 02:07 PM
ajxj9197
2009 WK
First is engine skid second is transfer case skid I believe third should be gas tank skid. That's what came on mine sorry if the pics aren't that good
ajxj9197 is offline
post #10 of 16 Old 08-18-2013, 05:12 PM Thread Starter
suzieque
2008 WK
He pics are great thanks. Is there a skid between the engine skid plate and the transfer case skid plate? Or is it just an open gap?
suzieque is offline
post #11 of 16 Old 08-18-2013, 05:22 PM
ajxj9197
2009 WK
No skid between those, open space but Definitely didn't have anything sitting low that I could imagine would get damaged. At work so I can't check I can snap a pic later of the space between if you'd like.
ajxj9197 is offline
post #12 of 16 Old 08-18-2013, 05:49 PM
Tango.
2008 WK
hmmm.. maybe he doesn't have a dpf.. what does that cost $1500?
fyi ... mine came with plastic plates and I added the oem metal ones...plus some 4xguard. front, rear , and belly.
Tango. is offline
post #13 of 16 Old 08-18-2013, 07:26 PM Thread Starter
suzieque
2008 WK
that's cool, I don't need a pic if its just an open space. thats the same place that has the flimsy plastic shield on my WK. I thought there may be a mopar bolt on metal shield on the hemi with the off road package. My guess is that 4x is the only option - unless I want to make my own skid plate for that area.
suzieque is offline
post #14 of 16 Old 08-18-2013, 07:33 PM
ajxj9197
2009 WK
Probably would be too hard. Just need to figure the dimensions, and figure out where you can bolt it too.
ajxj9197 is offline
post #15 of 16 Old 08-18-2013, 08:15 PM
BAH101
2008 WK
Steel Armadillo is looking at making one also, it was mentioned on their Facebook page.
BAH101 is offline
