Dipping headlight issue - JeepForum.com
post #1 of 5 Old 09-14-2013, 08:45 AM Thread Starter
Surfer01
2005 WK
If I have my headlights on bright and then flick them to dip them due to an approaching car, on a number of occasions this action has switched off the headlights.
I am not sure if I am doing something that causes this to happen as I have tried to make it do the same thing but no luck. Any one else have this happen?
Surfer01 is offline
post #2 of 5 Old 09-14-2013, 01:49 PM
LouC
2007 WK
This used to happen on my old 98 ZJ, switch from high (main) to low (dip) beam and the lights went out. I replaced the dimmer switch and that fixed it.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #3 of 5 Old 09-15-2013, 03:09 AM Thread Starter
Surfer01
2005 WK
I find that just by flickering the switch from high bean to low, it is physically moved to the "off" position. It just seems so easy to do accidentally?
Surfer01 is offline
post #4 of 5 Old 09-15-2013, 07:32 AM
LouC
2007 WK
The version you have may be different that the US version; in ours you turn on the lights by turning the very end of the switch; high/low is selected by moving the lever in and out. On the 98 ZJ there was a seperate on/off switch on the dashboard.
LouC is offline
post #5 of 5 Old 09-15-2013, 08:10 AM Thread Starter
Surfer01
2005 WK
Same here except when you flick it in a hurry, you accidentally switch off the headlights by the action of your hand "rolling" on the light switch. I am assuming it is because the the "turn" bit is very easy to move and the simple action of flicking the hand on the switch causes it to turn off the lights. I guess you cannot "tighten" it up to prevent this happening.
Surfer01 is offline
