digital thermometer - JeepForum.com
post #1 of 10 Old 02-16-2006, 02:12 PM Thread Starter
stephen
digital thermometer
Anyone else notice that it take awhile for the digital thermometer display to adjust to the correct temperture? For example, when i pull out of my garage where it is in the mid-60's to outside where it is in the mid-40's, it takes about 5 minutes to adjust.
I am wondering if there is some factory packaging/protective pieces around the thermometer housing that might be insulating it. Anyone know where the actual thermometer is on the commander?
stephen is offline
post #2 of 10 Old 02-16-2006, 06:38 PM
JeepFreak91
i hear before (on a gc) that it takes several minuets to adjust at a certain speed to get an accurate reading but i could be wrong
JeepFreak91 is offline
post #3 of 10 Old 02-16-2006, 06:55 PM Thread Starter
stephen
makes sense, but typically I am only going 10-20 miles per hour in the neighborhood
stephen is offline
post #4 of 10 Old 02-16-2006, 10:01 PM
SYCOHEMI
SYCOHEMI's Avatar
My wife's Cayenne S is the same way with the temp. It's always wildly off for 10 minutes or so, at the onset of coming out of the enclosed garage. I guess it takes some time for it to adjust.
'06 Commander Ltd, 5.7L Hemi, QDII, Midnight Blue, Gibson Exhaust, Raingler Net, K&N FIPK, Remote Start, Optima Yellow, Skid plates & Tow Hooks, Rocky Road 2.25 Lift, New Rear DT Shocks, 265/70R17 REVO's, 6061-T6 Custom Wheel Adapters, 4xGuard Rock Rails/Steps
'05 Land Rover LR3 SE
SYCOHEMI is offline
post #5 of 10 Old 02-16-2006, 11:12 PM Thread Starter
stephen
that seems like such a crazy design flaw...especially for a porsche. anyone know where the temp sensor is?
stephen is offline
post #6 of 10 Old 02-16-2006, 11:53 PM
INTREPER
facing the front of the jeep, the sensor is located directly behind the grill on the left hand side. It is very accesible. The sensor takes a few minutes to adjust because it sits behind the grill in an open space. THat entire space has to get to temp before it can give a proper reading. So after you drive around for a few minutes it gets it right. Hope that made some sense.
Why can't Jeeps and Hummers get along?
INTREPER is offline
post #7 of 10 Old 02-17-2006, 07:53 PM Thread Starter
stephen
great explanation..thanks!
stephen is offline
post #8 of 10 Old 03-15-2006, 05:41 AM
Bing
Actually, my thermometer seems to be just about right.
I've checked it with local weather reports and my outdoor clock/thermometer
and it seems to be pretty close...+/_ 3 degrees or so.
Bing is offline
post #9 of 10 Old 03-26-2006, 06:34 PM
Rehasher
my commander does the same, as did my neon before it.
Rehasher is offline
post #10 of 10 Old 06-08-2006, 06:01 PM Thread Starter
stephen
update on the temp gauge........ took my commander in for its 3000 mile check up. i saw the TSB on the temp gauge being slightly off, so I mentioned my problem to the service guy (the problem was that it took several minutes to adjust to the new temperature when i pulled out of the garage). ends up the sensor was set to relay temp info every ten minutes. the service guy set it to 2 minute relay intervals. it working much better now
stephen is offline
Exterior Thermometer jnnym21 ZJ Grand Cherokee Forum 12 12-11-2007 11:46 AM
thermometer and a/c not working right pink63impala ZJ Grand Cherokee Forum 17 07-07-2007 07:11 AM
thermometer calibration? bfr WK Grand Cherokee & XK Commander Forum 7 02-19-2007 07:02 PM
Thermometer Problem bootleg420 ZJ Grand Cherokee Forum 1 10-07-2005 09:04 PM
outside thermometer display davidmcg ZJ Grand Cherokee Forum 5 01-18-2005 10:33 PM
