Differential noise WK 2006 HEMI - JeepForum.com
post #1 of 8 Old 03-17-2017, 05:08 PM Thread Starter
JamesEric
I failed inspection. The shop says it is the diff but you cannot hear it when it is on the rack. I also need upper control arms and ball joints. How can be sure what is causing the noise? If it is the diff what is the best way to stop the noise? I can fix everything myself except the diff. You can only hear the noise while driving.
Thanks,
James
2006 WK 5.7 HEMI limited
JamesEric is offline
post #2 of 8 Old 03-17-2017, 05:20 PM
board350
Junior Member
2007 WK
Failed inspection because of a diff? What state you in man? What is the symptom? Is it whining or loose?
Sent from my XT1096 using Tapatalk
2007 WK Limited, 3.0L Merc CRD, QDII, OME HD Lift, GDE "HOT" Tune, CBE pipe, Mineral Gray Metallic
board350 is offline
post #3 of 8 Old 03-17-2017, 07:58 PM Thread Starter
JamesEric
Maryland. It is whining.
post #4 of 8 Old 03-18-2017, 06:04 AM
Nejeep
I expect you failed inspection due to the worn ball joints and control arms, not the noise from the differential. If its just a whine at certain speeds a differential will run for a long time with minimal risk of further damage. If it is making grinding or popping noises then it needs to be repaired asap. The best way to determine the cause of the noise is to tear the differential apart and inspect the gears and bearings. A good drive line shop would be my recommendation.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #5 of 8 Old 03-18-2017, 07:08 AM Thread Starter
JamesEric
Thanks for the help and comments. Any idea on the cost of teardown and/or repair?
post #6 of 8 Old 03-18-2017, 01:40 PM
durango-bob
2006 WK
A diff teardown and repair should be around $300 plus parts. But I agree with Nejeep - fix the ball joints and any other items noted on the inspection report and then get it reinspected. If it is just whining, you should pass.
durango-bob is offline
post #7 of 8 Old 03-18-2017, 04:54 PM Thread Starter
JamesEric
I plan to install the other parts next weekend and then try to pass inspection again.
post #8 of 8 Old 03-18-2017, 06:54 PM
nvrdone1
2007 WK
id remove the diff cover, drain the fluid & see if there are metal particles inside or chipped gear teeth.. clean it good with carb / brake cleaner. reinstall the cover with a new gasket & refill with gear oil. then see if the whine is still there. if it is, diffs can go along time with a slight whine.
nvrdone1 is offline
