Differential Fluid Other then 75w-140??? - JeepForum.com
post #1 of 8 Old 02-27-2013, 06:21 AM Thread Starter
stoops85
2005 WK
Quad Trac I No limited slip... Fluid Change Questions??
Finally Just got my Lift, Struts-Shocks, Tires, ball Joints, Tie Rods, etc done... Im cashed out and need to change my fluids in the diff's and Transfer Case.
Questions are 1. Have 3qt left of ATF+4 from Tranny Flush will this be a Sufficient amount for Transfer Case???
2. I have Quad Trac I Open Diff's What other Gear oil can I put in besides 75w-140 Dont have the cash atm for that specific fluid and my Diff's are starting to whin can I do 85w-90 or 85w-140 maybe 75w-90???
stoops85 is offline
post #2 of 8 Old 02-27-2013, 07:46 AM
blizzboy283
2005 WK
Google advance auto parts coupons. You'll probably find like a $40 off coupon and you can buy the gear lube online and pick up in store.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #3 of 8 Old 02-27-2013, 08:45 AM
caulk04
2008 WK
2nd that. I picked up 4qt of Mobil1 75w-140 for $58 with tax just this week.
I think the online code I used was A124, took $25 off.
http://www.cheaperseeker.com/Advance-Auto-Parts-coupons
caulk04 is offline
post #4 of 8 Old 02-27-2013, 12:44 PM
TMJeep
You only need one quart of ATF for transfer case. So you will be good on that.
98 Sport TJ 4.0L
Chile Pepper Red with Black Dual Tops
Trueflow Air Filter
31" BFG A/T
Cibies headlamps, plus 30 bulbs
other than that pretty much stock for now
TMJeep is offline
post #5 of 8 Old 02-27-2013, 05:06 PM
yzjwk
2005 WK
85w140 is only a little thicker then factory spec at startup , but you or the vehicle probably couldn't tell the difference so between the 3 it's the best choice . Seeing as you have the v6 and if your not planning on towing anything you could get away with the 85/75w90 too IMO
As said , your transfer case only holds 0.65L / 1.4pts
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #6 of 8 Old 02-27-2013, 07:19 PM
tjkj2002
2002 KJ Liberty
Man I can buy 10qts of the good gear oil for $58,that would be 85w-140 non-syn.
tjkj2002 is offline
post #7 of 8 Old 02-27-2013, 10:32 PM
fishinbama
2007 WK
I use 75-90. It was spec for Chysler 8.25 in the past. Differentials haven't changed much I think. Maybe not as good for towing.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #8 of 8 Old 02-28-2013, 06:58 AM Thread Starter
stoops85
2005 WK
I ended up getting 75w-90 mechanic at Chrysler said it will be fine since I don't have locking front and rear diffs and I dont tow... Anyhow thanks for the tip on the coupon guys got 4qts for 29bucks of Mobil1!!
05 Wk - 2" DayStar, 1.5" RC's, KYB Front and Rear, 255/75-17's M/T's, Rola Roof Rack, Spyder Bull Bar
stoops85 is offline
