Differential fluid change - Page 2 - JeepForum.com
post #16 of 30 Old 10-05-2010, 10:27 AM
JerseyGeorge
Spin it any way you want! 46000 miles and going strong.....NO chatter when turning....FLAWLESS operation in the deep snow we had last year.......PERFECT on the beach and dunes in NC!! Guess my Jeep is one of the "most" class
JerseyGeorge is offline
post #17 of 30 Old 10-05-2010, 04:44 PM
5318008
2005 WK
Correct me if I'm wrong, but QT1 and QT2 have open differentials front and rear, and therefore, should not require a limited slip friction modifier.
5318008 is offline
post #18 of 30 Old 10-05-2010, 06:46 PM
kentman
kentman's Avatar
2006 XK Commander
Sounds right to me. I have QD and QD-II on the WJ and XK, and that requires the modifier.
I cannot tell what JerseyGeorge has got. If he is QT1 or QT2, then that would explain why he has no issue without the modifier.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #19 of 30 Old 10-06-2010, 01:17 AM
JerseyGeorge
I have the QD II and yes it requires the additive modifier unless the gear oil your replacing it with has the friction modifiers in it. Since I use Mobil 1 75/140 gear lube and it has the friction modifier I don't add any and it has worked flawlessly!! NO chatter.....super performance in the snow and sand/dunes in NC!
I'm not telling people friction modifier isn't needed but I'm pointing out Mobil One, Amsoil and Royal Purple to name a few come with the friction modifiers in them already so NO additional FM is needed!
post #20 of 30 Old 10-06-2010, 05:50 AM
kentman
kentman's Avatar
2006 XK Commander
This is not the same for everyone. Others have complained about issues without the modifier when using Mobil 1 LS. I add the modifier, and I have no issues when adding it. I have never tried without, and I do not plan to try without.
If I were you, I would try to do some figure eights and see if you get any binding or hopping. On sand or snow going straight, you may get even slip on all wheels and not see the issue. Doing figure eights on flat ground, you may see more.
kentman is offline
post #21 of 30 Old 10-06-2010, 10:08 PM
JerseyGeorge
I guess I have a "special" Jeep
I don't do figure eights on the street or off-road so why would I do that? I assure you when driving in the snow and the beach I made a couple turns......some even sharp turns. NJ is full of sharp turns, off-ramps, u-turns, besides This isn't my first rodeo!
post #22 of 30 Old 10-07-2010, 04:35 AM
kentman
kentman's Avatar
2006 XK Commander
Personally, I would rather not play with fire over $10 on a bottle of friction modifier. Worst case if I am wrong, I am "throwing $10 away" every 15K miles. I can live with that. Different strokes for different folks.
kentman is offline
post #23 of 30 Old 10-07-2010, 07:33 AM
I8AHUMR
I add the modifier even with M1. I've gotten chatter from the rear while doing tight figure 8's. It's $7 from the dealer here. Buy one bottle just in case, allow for a few ounces to be added, and add it as needed.
There's a common brand that is always in advance or auto zone around here. Don't be tempted if you run across it. It says in fine print that it's not for the GC LS's
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #24 of 30 Old 10-07-2010, 07:52 AM
acort
2005 WK
Make sure you buy some break cleaner to spray out the diff when the covers off! It makes a huge difference!
acort is offline
post #25 of 30 Old 10-24-2010, 03:13 PM
tazer15
im getting ready to change mine why would wiping the oil off the diff covers with brake cleaner make a huge diff ?????that little bit of old fluid on them cant add up to an ounce.if their that sensitive i think this thing will be sold as quick as i bought it
tazer15 is offline
post #26 of 30 Old 10-24-2010, 03:49 PM
JerseyGeorge
If you're going to change it you may as well do it right. Getting the cover off and draining the fluid then reinstalling all the above is the hard part. Spraying a can of brake cleaner is cheap and EASY!
post #27 of 30 Old 10-24-2010, 08:12 PM
gornoman
2006 WK
acort was saying to spray down the gear set, not just the diff cover.
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
post #28 of 30 Old 10-25-2010, 09:34 AM
Jscheier
2007 WK
Spraying down the gear set with brake parts cleaner will help you during the inspection you are doing while changing the fluid (you are inspecting, right?). Gets everything clean and shiny so you can look for abnormal wear on the ring, chips, etc.
2007 Jeep GC QD2 CRD (GDE equipped Toy Hauler)
2012 Boss 302 (Track Toy)
Jscheier is offline
post #29 of 30 Old 10-25-2010, 09:43 AM
djfxall
2005 WK
are there limited slip tags on the diff if the fluid is needed?
djfxall is offline
post #30 of 30 Old 10-25-2010, 10:20 AM
maxst2
2006 WK
That's usually not a good idea. Brake cleaner usually leaves a residue. If you have water in your diff, then you should...but if not you really shouldn't.
Honestly, if you have QT2 do yourself a favor and go to riddler and pick up a new rear diff cover. Stock cover is a piece of foil compared to it. lol Not a bad price either.
2006 65th Anni. Grand Cherokee 4x4 in black w/ 4.7L V8
maxst2 is offline
differential , fluid , maintenance , wk
WK - Differential Fluid Change BigSensFan WK Grand Cherokee & XK Commander Forum 16 08-31-2016 01:01 PM
Differential fluid change steve L. ZJ Grand Cherokee Forum 15 07-04-2010 10:29 AM
Differential fluid change 06 Commander bsork WK Grand Cherokee & XK Commander Forum 1 05-15-2008 03:18 PM
Differential fluid change Rok93gc ZJ Grand Cherokee Forum 60 01-02-2007 08:58 PM
How to change differential fluid Grand96 ZJ Grand Cherokee Forum 6 09-21-2002 11:24 AM
