Differential fluid change - JeepForum.com
post #1 of 30 Old 09-28-2010, 09:01 PM Thread Starter
grandcher0kee06
2006 WK
How do i know when to change my differential fluids? i have 54k miles, and when i bought it, it had 46k miles and the dealership said they couldnt tell the condition of the fluids without taking the differential apart, and by then they would just go ahead and change them. so my question is should i go get my fluids changed? i go offroad couple times every week or so. if this makes any difference.
2006 Grand Cherokee Limited, QDII, 4.7L V8, 245/65/17 Firestone Destination LE, smittybilt rear d ring shackle reciever,
Blue WK Club Member #9
grandcher0kee06 is offline
post #2 of 30 Old 09-28-2010, 09:03 PM
odinseye84
I would absolutely do it. You dont know if it has been changed before, and at 54k its likely far overdue. Much cheaper and easier to do yourself, however...I think I did mine for under 50 dollars including the lube, sealant, gasket scraper, etc.
odinseye84 is offline
post #3 of 30 Old 09-28-2010, 09:13 PM Thread Starter
grandcher0kee06
2006 WK
okay, thats what i was thinking. but where do i go to get all of the items needed (and what are those items) to do it myself, and directions on how to do it
post #4 of 30 Old 09-28-2010, 10:05 PM
Texas WJ
Texas WJ's Avatar
2005 WK
You'd be amazed how dirty it gets in there.
You can get the diff fluid (75W-140 synthetic) at any parts store. The friction modifier, one bottle per diff, can be had at the dealer. It's not expensive. The transfer case fluid is best bought there as well.
You can suck the old fluid out of the rear diff instead of removing the cover if you so choose. The front diff has a drain.
I would do the transfer case as well while you're under there.
This link is for the SRT-8, but the process is the same.
It's a dirty swap. I have yet found a way to not make this a mess, but it's pretty simple.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #5 of 30 Old 09-29-2010, 01:23 AM
JerseyGeorge
75-140W Mobil one gear lube I recomend that you go to. jeeps.com/wk_maintenance.htm For capacities and recommendations! M1 gear oil dosen't need friction modifier for the limited slip!
JerseyGeorge is offline
post #6 of 30 Old 09-29-2010, 02:16 AM
myjeeplovesmud
every 30k..... thats what most jeeps have in the manual.
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
post #7 of 30 Old 09-29-2010, 03:30 AM
Feffman
2005 WK
Just had the dealer do both differentials, transfer case and transmission. Not inexpensive but a lot less costly then replacing parts or new Grand Cherokee.
Feff
Feffman is offline
post #8 of 30 Old 09-29-2010, 08:11 AM
myjeeplovesmud
transfer case and diffs are super easy tranny i leave to the mechanic mostly because of the mess
post #9 of 30 Old 10-02-2010, 11:33 PM
sabre364
2007 WK
what do you guys use as a gasket scraper? just a plain old flat blade wallpaper scraper thing?
and when popping off the rear cover you just take off most of the bolts and crack it open with the same scraper and let it drain?
sabre364 is offline
post #10 of 30 Old 10-02-2010, 11:44 PM
JerseyGeorge
Putty knife works great. Loosen all the bolts and pry bottom of cover away from diff so it drains.....then remove cover.
post #11 of 30 Old 10-03-2010, 05:02 AM
kentman
kentman's Avatar
2006 XK Commander
I believe that is not true. I use the modifier with Mobil 1 75W140LS. I would read some of the other posts on this topic. I just did the WJ diffs a week ago. I did the XK last summer.
Mobil 1 is good stuff, but there is a difference between LS oil and friction modifier for oil as specified by Mopar.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #12 of 30 Old 10-05-2010, 12:45 AM
JerseyGeorge
Mobil 1 is good stuff, but .
Read the specs on the M1! Besides I've been using it for the last 25K with NO problems and NO additives!
"there is a difference between LS oil and friction modifier for oil as specified by Mopar"
Please explain the difference! FM is for use in LS applications.....LS isn't a lube, it's an additive that M1 contains and is sufficient for MOST applications!
From Mobil's site:
Mobil 1 Synthetic Gear Lube 75W-140 LS contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
post #13 of 30 Old 10-05-2010, 05:55 AM
kentman
kentman's Avatar
2006 XK Commander
There are other threads on here on this topic. Do a little searching, and you will see what I am talking about.
The vehicle will work without the modifier, but it will not perform as designed. There are ways to test if the diffs are working properly.
kentman is offline
post #14 of 30 Old 10-05-2010, 05:59 AM
kentman
kentman's Avatar
2006 XK Commander
I know that LS is not a lube. However, 75W140LS is a gear oil that has been modified. The question is whether it has been modified properly per Mopar specs. Unless Mopar says that Mobil 1 75W140LS is all that you need, I would be careful on your assumptions.
kentman is offline
post #15 of 30 Old 10-05-2010, 09:38 AM
colinzj
2006 WK
Yeah, it's the "most" that's the important part here. That doesn't mean "all," and Chrysler has always recommended Jeep specialty differentials use the additive regardless of what lube you use. In the case of some differentials, it was very, very obvious the Mobil LS wasn't sufficient.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
differential , fluid , maintenance , wk
WK - Differential Fluid Change BigSensFan WK Grand Cherokee & XK Commander Forum 16 08-31-2016 01:01 PM
Differential fluid change steve L. ZJ Grand Cherokee Forum 15 07-04-2010 10:29 AM
Differential fluid change 06 Commander bsork WK Grand Cherokee & XK Commander Forum 1 05-15-2008 03:18 PM
Differential fluid change Rok93gc ZJ Grand Cherokee Forum 60 01-02-2007 08:58 PM
How to change differential fluid Grand96 ZJ Grand Cherokee Forum 6 09-21-2002 11:24 AM
