Quantcast Differential fluid change 06 Commander - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Differential fluid change 06 Commander
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 05-15-2008, 03:57 PM   #1
bsork
2006 XK Commander
HI all
I am new to this forum and I am looking to perform 15k maintenace on my 06 commander. Does the differential fluid need to be changed? What oil should I use and do you need to remove the covers or can you just siphone it out? I have not done any off roading in this vehicle to date. The dealer wanted $264.00. Seems alot.Is there a DIY site for this?
Thanks
BS
bsork is offline   Reply With Quote
Old 05-15-2008, 04:18 PM   #2
Shirai_Ryu
Differential Fluids are recommended to be changed at 15,000 miles.
15,000 Maintenance 2006 XK 3.7L:
Change the engine oil and engine oil filter, if not replaced at 3 months.
Inspect the engine air cleaner filter, replace if necessary.
Drain and refill the front and rear axles.
Inspect the exhaust system.
Inspect brake hoses.
Check the engine coolant/anti-freeze level, hoses, and clamps.
After completion of off-road operation, the underside of the vehicle should be thoroughly inspected. Examine threaded fasteners for looseness.
MOST (not all) 2006 XKs will take 75W140 Synthetic gear lube.
The Front differential has drain & fill plugs, the cover is extreamly diffacult to remove. The Rear differential only has a fill plug, normally the cover is removed for servicing, but according to your warranty manual "Drain & Refill" is acceptable, although I would recommend pulling the cover to get out as much debris as possible.
Wow, thats cheap, Its $405 for the differential services here, ya just checked - $190 just for the fluid & RTV (parts) only.
Shirai_Ryu is offline   Reply With Quote
Glock Forum
