A different yellow wire problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > A different yellow wire problem
Savvy FOX IFP 4" Lift Shocks in StockOnly 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 01-09-2015, 10:41 AM   #1
tokenwon
There's no power going to the yellow wire.. Could this only be the WIN/ignition switch problem?
Basically, I'm trying to trace the wire but I'm not sure where it goes. The only yellow wire I can find leading to the WIN is yellow with a stripe.
Thanks
tokenwon is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 11:43 AM   #2
JKM
2005 WK
there is also a relay for the starter. Have you checked for power there?
JKM is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 05:44 PM   #3
tokenwon
I swapped relays around.
I guess I'll have to hope a new ignition switch/WIN does the trick.
Unread 01-13-2015, 01:58 PM   #4
tokenwon
JKM, you're on the money. No power going to relays 47b and 48b.
It looks like I'll have to take the fuse box apart and have a look. Maybe rewire those connections.
Anyone have any advice? Anything may help!
