Different kind of lift question - JeepForum.com
post #1 of 14 Old 04-16-2013, 07:53 PM Thread Starter
Megs_Revenge
2005 WK
So my question is: does your WK fit in your garage with your lift on?
Currently I have no lift on my WK, the bf has a super lift on his. We live in a townhome, and with the mirrors folded in, mine fits and his doesn't. Our garage is standard size and we will be moving out once our lease is up so this set up is ok for now.
But before I do lift it, I just want to make sure I can still use the garage (any garage). I only plan on a 2 to 3in lift at most. Of course the biggest challenge is getting through the door. We chose this place over the fact that his lifted TJ fit. But max, the wrangler is only 6'2" or so.
2005 Silver WK 5.7L Hemi
Silver WK club #69
Oo|||||||oO
Megs_Revenge is offline
post #2 of 14 Old 04-16-2013, 08:16 PM
Jaashua
2005 WK
Unrelated, Monroeville is awesome. That is all.
Jaashua is offline
post #3 of 14 Old 04-16-2013, 08:51 PM
bhawks28
2014 JK Wrangler
Funny you mention this...I looked at a few prospective houses today, and had to cross off two of the four because my WK with OME lift wouldn't fit in the garages! And of the two that it would fit in, I don't think my WK would fit in either after new tires.
2014 JKU Rubicon
bhawks28 is online now
post #4 of 14 Old 04-16-2013, 10:40 PM
R4TCHET
2005 WK
i dont know how standard my garage is but i have a 2" lift 32" tires and a roof rack and i just squeeze by
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #5 of 14 Old 04-17-2013, 06:29 PM
Budasac
2005 WK
A "Standard" garage door is 8' wide x 7' high, I believe that is the most popular size (also the size I have). I recently got new doors put in with new openers. With the old door my WK would just fit with a 2" lift, 32s, and a Rola because the door blocked 6"-8" of the opening. My new doors open completely leaving a full 7' height. I think it was actually the old door openers more then the doors themselves. (The old ones had no adjustment.)
So, basically, unless you have a real low ceiling in the garage, you should be able to adjust the door (or buy a new door opener) so you get the full 7' clearance.
Budasac is offline
post #6 of 14 Old 04-17-2013, 10:08 PM
sixfoot9psu
2005 WK
I have a 3" lift, 32" tires, and a roof rack and mine barely fits! If I mounted my rola rack the way it's made, it wouldn't fit, but with the brackets reversed for a lower profile it fits
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #7 of 14 Old 04-18-2013, 08:52 AM
bhawks28
2014 JK Wrangler
I'm going to have to look into doing this then
2014 JKU Rubicon
post #8 of 14 Old 04-18-2013, 10:19 AM
ca07wk
2007 WK
how'd you mount it with the brackets reversed?
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #9 of 14 Old 04-18-2013, 10:46 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I will have to measure again when I get home to be sure, but with my SL, 35" tires, and a Gobi rack, my clearance is something like 6'7". I wrote it on a little piece of paper by my gages, that way I know if I can clear a parking garage down town. This however does not include my CB antenna which is a few inches taller than my rack.
Omelet is offline
post #10 of 14 Old 04-18-2013, 03:28 PM
sixfoot9psu
2005 WK
Good, I'm still taller than your Jeep!
Instead of putting the rola brackets on top of the factory crossbars, put them underneath. I think buda was the first one to do this and if you search you should be able to find more info on it
post #11 of 14 Old 04-18-2013, 03:42 PM
Budasac
2005 WK
Check out post #279 in my Build Thread.
Budasac is offline
post #12 of 14 Old 04-18-2013, 04:18 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha, perks of having a slim rack! I just measured and it looks like at the rear of the rack (heighest piont of the Jeep) it measure right at 6'7", so I would say my minimum is 6'8". Also like I said the antenna is still taller at 7'2". If I had to clear overhangs often then I would probably instal a quick disconnect.
Omelet is offline
post #13 of 14 Old 04-18-2013, 05:08 PM
ca07wk
2007 WK
Thanks
ca07wk is offline
post #14 of 14 Old 04-18-2013, 07:29 PM Thread Starter
Megs_Revenge
2005 WK
Hmmm.. so looks like I'm looking at a smaller lift till we buy a place and/or build a garage. My standard antenna whacked off the crossbeam in ours so much I just ended up buying a short one.
Silver WK club #69
Oo|||||||oO
