Diff fluid - JeepForum.com
post #1 of 6 Old 10-28-2013, 07:15 AM Thread Starter
RUGLAYR
Diff fluid
So I'm getting ready to change my diff fluid 2005 wk limited 4.7 and was wondering if when using Mobil 1 75w-140 LS do I need to add limited slip additive and can I also use the same fluid front and rear. I have read many posts but can't seem to find a for sure answer. Thanks
RUGLAYR is offline
post #2 of 6 Old 10-28-2013, 07:22 AM
caulk04
2008 WK
I don't trust any fluid to negate the need for LSD additive, so I always use it. I always use the factory additive also, seems to work better to me and it doesn't really cost much.
The 75w-140 is good front and rear.
NOW - Do you have QDII or QTII? If 'Drive', you need the additive. If 'Trac', you don't.
Not sure? Count the rear diff bolts. 12=drive 10=trac
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 6 Old 10-28-2013, 07:45 AM Thread Starter
RUGLAYR
I have the 10 bolt rear
RUGLAYR is offline
post #4 of 6 Old 10-28-2013, 08:16 AM
caulk04
2008 WK
So you've got quadra-trac. Standard open differentials that don't need LSD additive.
caulk04 is offline
post #5 of 6 Old 10-28-2013, 08:20 AM Thread Starter
RUGLAYR
Great. Thanks very much for your knowledge
RUGLAYR is offline
post #6 of 6 Old 10-28-2013, 10:19 AM
lekmedm
2007 XK Commander
^^^This is the definitive answer!
2007 Commander Overland / 4" SuperLift / 285/70R17 Cooper Discoverer ST Maxx / + other great stuff
lekmedm is offline
