Diesel WK: Tranny Upshift Trick - JeepForum.com
post #1 of 2 Old 09-11-2007, 03:42 PM Thread Starter
boxcab
boxcab's Avatar
2007 WK
Maybe this is in the manual, but I'm headed for the sack so I'm not looking it up.
It seems to me that at certain speeds, 25 mph and 35 mph, common around town, the CRD is in a lower gear than is needed. Engine speed is about 1600 rpm. But I discovered today that pushing the shifter to the right at these speeds up-shifts the transmission to the higher gear, dropping engine speed to around 1200 rpm. Still plenty of response, just more growl. My ScanGauge II shows a slight improvement in economy, too.
Food for thought...
Doug
2007 WK CRD
boxcab is offline
post #2 of 2 Old 09-11-2007, 05:19 PM
flyrx
flyrx's Avatar
2007 WK
I can confirm that, I've been experimenting with that recently myself. During most driving, the auto does a good job, and I only used the autostick to downshift for engine braking. I recently discovered that in the above mentioned speed range (or even as low as 10-15 mph), using the upshift function also seems effective at lowering the RPM.
flyrx is offline
96 Grand outo trans 3rd gear upshift. Trapmark ZJ Grand Cherokee Forum 2 12-02-2009 04:42 PM
WJ 3.TD (2000): No upshift from 3rd to 4th gear diplo ZJ Grand Cherokee Forum 1 08-09-2008 04:23 AM
My 44RE won't upshift to 2nd Steve98 ZJ Grand Cherokee Forum 2 02-27-2008 12:08 PM
upshift light blkfreedom03 ZJ Grand Cherokee Forum 4 07-16-2005 04:56 PM
holds gear, won't upshift jmsjeep ZJ Grand Cherokee Forum 5 11-15-2001 07:11 PM
