Diesel smell in cab - JeepForum.com
post #1 of 4 Old 02-16-2014, 09:13 PM Thread Starter
VulcanWDE
2007 WK
Diesel smell in cab
Every once in a while I notice an exhaust smell that seems to come through the vents whenever I come to a stop. It resolves once I'm back up to speed. I've been trying to look for patterns, but it doesn't do it every time. Any ideas??
"Worrying is like a rocking chair...it will give you something to do, but it won't get you anywhere"
VulcanWDE is offline
post #2 of 4 Old 02-16-2014, 09:47 PM
furiousbudy
2008 WK
Remove you engine cover and rubber pads, check around your injectors if its wet, mine had a bad seal on one injector.
2008 Grand Cherokee CRD Limited 185,000KM, Kendall 5W40 Euro
2007 18CK Pionneer Travel Trailer
furiousbudy is offline
post #3 of 4 Old 02-17-2014, 07:47 AM
jaje
2007 WK
Also check the fuel filter which is in the engine's V underneath the covers.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #4 of 4 Old 02-17-2014, 07:58 AM
james_2k
2003 WJ
sure its diesel and not oil?
when its leaking from the turbo inlet you sometimes get a waft of hot oil smell.
james_2k is offline
