did i read this right? (ome rear lift,spacer front lift) - JeepForum.com
post #1 of 14 Old 05-16-2010, 06:34 PM Thread Starter
osd
i was doing some research on here and i read on one of the posts that your better off doing a ome or rustys lift in the rear and just using spacers for the front if you plan on replacing rear shocks
if thats the case its still the same price as most kits. ive seen rusty rear 2" springs going for $130 for the set and rustys rear shocks going or $65 a set. spend $88 for rustys 2" spacers upfront and you got a lift.
*i just used rustys as an example. im sure the ome is better.
did i totally misunderstand what i read or did i understand it correctly?
osd is offline
post #2 of 14 Old 05-16-2010, 07:31 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
If you did the OME coils in the rear and some spacers in the front it would not be even. OME coils will give you more of a 3" lift. If you are wanting to go this route i would suggest the rustys coils.
Omelet is offline
post #3 of 14 Old 05-16-2010, 08:57 PM Thread Starter
osd
if i did rusty 2" coils with rusty in the rear and rusty coils in the front what would i put for shocks upfront?
osd is offline
post #4 of 14 Old 05-16-2010, 09:40 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I would recommend either Bilstein or OME. I have the OME and I love them. The ride quality is awesome!
Omelet is offline
post #5 of 14 Old 05-17-2010, 07:32 AM
koj
2010 WK
I have Rustys spacers in the front and OME springs in the rear. OME shocks all around. Im very satisfied. The original rear springs sagged (see photo in my profile) so I changed the rear springs when I changed the shocks. The OME springs and shocks are a little stiffer than the original.
WH 2010 CRD. Bilstein shocks, Rustys 2" BB front, OME HD springs rear. 265/70x17
koj is offline
post #6 of 14 Old 05-17-2010, 07:34 AM
koj
2010 WK
Sorry shocks are Bilsteins
koj is offline
post #7 of 14 Old 05-17-2010, 05:41 PM Thread Starter
osd
did you use 2" lift springs with regular/stock configured bilstein shocks?
i really dont do any serious 4 wheeling aside from the beach and the trails to the beach. i wanna be able to fit 265 or 255/75.
osd is offline
post #8 of 14 Old 05-17-2010, 07:51 PM
koj
2010 WK
2" lift springs in the rear with standard length shocks. No problem
koj is offline
post #9 of 14 Old 05-17-2010, 08:41 PM Thread Starter
osd
why not just do springs upfront too?
osd is offline
post #10 of 14 Old 05-18-2010, 03:50 AM
koj
2010 WK
Started with a BB front and rear. When the rear later was sagging, springs were the logical choice.
koj is offline
post #11 of 14 Old 05-18-2010, 01:54 PM Thread Starter
osd
did you take the rear bb lift out or leave it in? what im picturing in my head is the rear of your jeep having just 2" lift springs and the front have the bb lift. if you switched to just springs in the rear why not do the same in the front?
osd is offline
post #12 of 14 Old 05-18-2010, 02:21 PM Thread Starter
osd
im a moron i forgot the front is ifs.
my last truck (s10 blazer) was a torsion bar ifs, what a pain in the d*ck. so ill just do the bb up front, and shocks/springs in the rear.
osd is offline
post #13 of 14 Old 05-18-2010, 04:26 PM
koj
2010 WK
If I would do it again I would choose Rock Crawler 3,5" for easy installation. Rustys and the like require taking the front struts off the wehicle and some cutting of bolts. Other BB kits need you to diassemble the front struts which is even mor work with compressing the spring etc.
koj is offline
post #14 of 14 Old 05-18-2010, 06:07 PM Thread Starter
osd
thats good to know, thanks.
osd is offline
ZJ Front to rear lift How much lift should i expect? jeep95xj ZJ Grand Cherokee Forum 30 02-08-2015 08:00 PM
Spacer lift has caused SEVERE noise in the rear crump582 WK Grand Cherokee & XK Commander Forum 19 11-13-2014 07:58 AM
zj front to rear spring 4" lift rear track bar info autobeamhotmail ZJ Grand Cherokee Forum 3 03-01-2007 04:07 PM
wj lift insight needed!!! OME or spacer lift mikkjroverland ZJ Grand Cherokee Forum 0 08-24-2003 05:25 PM
