Diagnostic Trouble Codes for OBD II and Details - Page 2 - JeepForum.com
 1Likes
post #16 of 22 Old 03-20-2009, 09:03 PM Thread Starter
yrkoverland
Originally Posted by justa4banger View Post
WOW, nice collection, i bet that took some time to type out LOL
Great FAQ thread
Hope it helps, these are more generic and not so Jeep specific but I figure if people can pull the codes this will at least get them in the right area.
yrkoverland is offline
post #17 of 22 Old 07-19-2009, 03:03 PM
dirtbiker00
2002 XJ Cherokee
Just my luck, mine isn't on the list!!!!! P0456
My codereader booklet lists it as a "EVAP system leak very small"
Does anyone know if this means I have to replace the charcoal canister, or just look for a hose or pipe leak?
dirtbiker00 is offline
post #18 of 22 Old 10-22-2009, 07:08 AM
j_a1963
Rough Idle On A Wj 2001 With 4.7
i get a code p0353 i change the coil and all the plugs and still get same code(after cleaning them) any ideas?????
j_a1963 is offline
post #19 of 22 Old 03-20-2011, 03:04 PM
ashy22
2005 WK
P1417 on the dash DTC readout
My code P1417 isn't on the list either????
Any ideas anyone?
it sounds like I have one or more cylinders not firing properly.
I have had the orange "check engine" light coming on and off for the last few week now.
very confusing!!!
Thanks in advance.
Paul
2005 GC 5.7 Hemi(WH-Export)QDII
1971 Corvette 454
1969 Plymouth RR 383
ashy22 is offline
post #20 of 22 Old 07-08-2011, 06:07 PM
countryboy5544
i found one that isnt on here. p1593 is speed control switch 1/2 stuck
countryboy5544 is offline
post #21 of 22 Old 08-07-2011, 03:55 PM
kittyhawk
How About code P2503, The check gauges light come on today and pulled this code. I had some funny transmission issues and loss of power issues before this code came up. the wife was driving out by Harpers Ferry toady, and If freeked her out. So Need some advice ASAP.
kittyhawk is offline
post #22 of 22 Old 10-23-2013, 01:07 PM
Zlartibartfast
2007 WK
This is a good thread to bump up...
I had P0191 "fuel rail pressure sensor out of range...." (or words to that effect) show up as a "grey code" (pending fault, not confirmed) a few times. The other day, it came back confirmed, & threw a CEL. Turned out to be a pinhole leak in the fuel line leading from the filter housing. Replaced hose, code gone
Zlartibartfast is offline
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 01:59 PM
'94 ZJ Diagnostic Codes BFI ZJ Grand Cherokee Forum 2 06-25-2008 10:04 AM
'95 ZJ trouble codes and diagnostic question bobiam ZJ Grand Cherokee Forum 6 01-29-2008 12:04 PM
Diagnostic Trouble Codes 12 & 31 Saturdaynight ZJ Grand Cherokee Forum 4 09-21-2005 07:58 AM
