Dependability W5A580 Automatic Tranny - JeepForum.com
post #1 of 11 Old 02-28-2011, 03:59 PM Thread Starter
stryker221982
2005 WK
Is this tranny dependable? Mine has 93000 miles on it. Just had a tranny service done, no metal shaving in the pan. Seems to shift a little faster and tighter now.
I know the 3.7 is supposedly durable if you maintain it, havent heard much about this tranny though.
stryker221982 is offline
post #2 of 11 Old 02-28-2011, 04:21 PM
fitbmxseries1
1987 YJ Wrangler
probably last a while if maintianed properly, the real test is to see alot of wk on the road pushing 200k in the next 3 years. I know im having some issues with my tranny were it clunks like crazy when its cold.
2005 Jeep grand Cherokee WK 2" rough country lift 1.25 wheel spacers 255/75/17
Blue WK club #5
1987 Jeep Wrangler YJ, random leafspring budget lift ith 33s on 16s and V8 swap.
1999 Jeep Cherokee XJ --SOLD.
fitbmxseries1 is offline
post #3 of 11 Old 02-28-2011, 04:24 PM
Budasac
2005 WK
Did you flush or drain and fill? And is this the first time you've serviced it?
I just hit 80,000 and need to service mine.
Edit: I believe this is also the same trans the SRT8 has in it. So.... if it can handle that beast, I'm sure it has no issues handling the 3.7L.
Budasac is offline
post #4 of 11 Old 02-28-2011, 04:46 PM
cmdrjim
2006 XK Commander
It is the same transmission in the SRT8, so they put it behind a 6.1L V8. Changing the fluid and filter is the key,
cmdrjim is offline
post #5 of 11 Old 02-28-2011, 08:17 PM Thread Starter
stryker221982
2005 WK
I used to work as a parts manager at a Ford dealer and there we used a tranny flush machine and a chemical additive that was supposed to help clean. Pros to this was it flush the entire system which worked well on vehicles which did proper maintance . Cons didnt change the filter or clean/inspect the pan. Also on older vehicles not properly maintained you ran the possibility of clogging the valve body causing more harm then good.
the dealer i brought it to believes more in a drain from the pan change all the filters in this case one and clean/inspect the pan and replace the pan gasket and refill with fuild.
I always have the dealer do this kinda work for the "just in case" clause where if something gets ruined then they are liable
post #6 of 11 Old 02-28-2011, 08:20 PM Thread Starter
stryker221982
2005 WK
is the W5A580 the same as the 545RFE? i downloaded a factory service manual and it only list 2 trannys for this the, 545RFE and the NAG1
my as built data shows the W5A580 as the option used
post #7 of 11 Old 02-28-2011, 08:37 PM
justa4banger
2007 WK
Strker, the 2 trannies are different...
NAG1 is a W5A580...
aslo do some searching around as there are part numbers on this forum do acquire a Dipstick for your NAG1/W5A580
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #8 of 11 Old 02-28-2011, 08:41 PM
90grandoneer
90grandoneer's Avatar
2006 WK
No, it is not the same as a 545RFE, but the NAG1 is the W5A580. It is a Mercedes based transmission and, IMO, is far superior to the 545. It is also used in the 6.1 SRT8 WK, and I have one in my Hemi Magnum. I have the 545 in my Hemi WK, which cannot (at least on my 06) be made into a true autostick with a tuner like the W5, has better gearing (very similar to the early GM Hydramatics), and a better shift schedule and converter lockup scheme, just to name a few. If I could easily convert, I would.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is online now
post #9 of 11 Old 02-28-2011, 10:32 PM
Lt_JWS
2006 XK Commander
Had a Chrysler 300C with a Hemi and W5A580 come into our shop about a year ago with hardly any fluid in it and replaced a leaking seal(or wire connector) and serviced the tranny and they haven't had any problems since... I know the 545RFE would have died from that
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline
post #10 of 11 Old 03-01-2011, 06:20 AM
Budasac
2005 WK
There is a TSB about flushing. Chrysler doesn't recomend it, and they say never use any chem additive. The dealer actually did the right thing. My dealer is still pushing the flushes. I guess they paid all that money for the machine and want to use it.
Budasac is offline
post #11 of 11 Old 03-01-2011, 07:34 AM
BonesWK
2006 WK
sure would have - I know mine did
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
automatic transmission (W5A580) urezki WK Grand Cherokee & XK Commander Forum 8 04-13-2010 12:36 PM
Automatic Tranny question Jeep2k55 ZJ Grand Cherokee Forum 14 01-24-2009 03:47 PM
changing trans fluid on W5A580 stgry1 WK Grand Cherokee & XK Commander Forum 60 11-16-2008 07:56 PM
W5J400/W5A580 swap ---- WK Grand Cherokee & XK Commander Forum 1 07-31-2008 06:28 PM
2000 gc dependability 88wagon ZJ Grand Cherokee Forum 2 01-05-2007 07:38 PM
