Deciphering build sheet 4wd system - JeepForum.com
post #1 of 4 Old 07-25-2013, 09:36 PM Thread Starter
ajblbv
Howdy. So deciphering build sheet for a CRD I'm looking at. It says "AWBP Quadra-Drive II (R) 4WD System" but also "DHXS Quadra-Trac II Full-Time,Active 4WD" later on. The limited slip axles are listed. Why does it reference qt2 if its qd2? Any guidance is welcome, thanks!
08 WK Limited 5.7L QT2
ajblbv is offline
post #2 of 4 Old 07-25-2013, 10:54 PM
jjt250
2007 WK
QTII and QDII use the same NV245 transfer case. QDII adds the ELSDs. My CRD is also equipped with QDII and the build sheet says the same as yours.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #3 of 4 Old 07-26-2013, 05:52 AM
sunoff
2010 WK
I think QTII is the base and QDII is an addition to the base? mine has both listed as well, but is def QDII
not stock WK and still working on it
almost modified OME HD
bunch of heavy crap
Superlift ordered
sunoff is offline
post #4 of 4 Old 07-27-2013, 10:17 AM
trax95008
2006 XK Commander
Exactly. QDII is built on top of QTII.
trax95008 is offline
