Dash lights flickering then U1417 - JeepForum.com
post #1 of 12 Old 07-18-2012, 07:53 AM Thread Starter
Briceronii
2006 WK
I had an interesting ride into work this morning. First i started up the 5.7 for 10 seconds before ALL the lights flickered on my dashboard. They stayed on for 3 seconds then went off. Sitting there like a deer in headlights trying to figure out what just happened, and it happened again. ALL the lights came on and i also noticed the interior fan speeed increased without me touching it. Drove to work which is only 7 miles away. While i was driving the same thing happened again. This time after the lights went out 2 lights remained on
Electronic Stability Program (ESP)/Brake Assist System (BAS) Indicator (22)
and
Traction Control/Electronic Stability Program (ESP) Indicator (16)
The other thing that happened was the gauges - spedometer and RPM gauge both went to 0 and then went back to normal while i was driving.
When i arrived at work i did the computer test and recieved an erorr of
U1417. I've read that this is a speed sensor but why would this cause all the lights to activate.
Thank you for reading this and for the help!
Briceronii is offline
post #2 of 12 Old 07-18-2012, 09:21 AM
05WKinPA
2005 WK
How old is your battery?
Rocky Road & OME MD hybrid lift / AEV Pintlers / 32" BFG Mud Terrains / Four X Doctor rear diff guard / JBA UCA's / 4XGuard Belly Skid / Stillen cross drilled rotors
05WKinPA is offline
post #3 of 12 Old 07-18-2012, 11:36 AM Thread Starter
Briceronii
2006 WK
It's a NAPA 75 Legend International
with a date of Feb. 09
post #4 of 12 Old 07-18-2012, 07:41 PM
Shafer57
2006 WK
I'd hook up a battery charger and confirm standard voltage prior to worrying. Could be just a battery, and that's gunna be the first step IMO.
It's over 3 years old and although that's not exactly a long time; depending what your weather conditions are like (hot to cold, etc.) could dramatically effect battery life.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #5 of 12 Old 07-25-2012, 07:22 AM Thread Starter
Briceronii
2006 WK
I will try that thanks!
post #6 of 12 Old 07-25-2012, 09:07 AM
ecollins7
2006 WK
I had this happen to me a few weeks ago, but my fan didn't get affected. All my lights on my dash would light up and then I would loose everything on the instrument cluster for a second.
I replaced the ignition switch and the fixed that problem but the ESP and bas lights kept coming on.
So I replaced the tps sensor and cleaned the throttle body and it hasn't done it since.
ecollins7 is offline
post #7 of 12 Old 07-25-2012, 10:05 AM
JKM
2005 WK
Ignition swtich is likely the problem as your battery seems somewhat recent. It's only about $50 if I remember correctly and about one hour to install. Instructions might be on here if you search or are in the service manual
JKM is offline
post #8 of 12 Old 07-25-2012, 10:12 AM
skrach77
2005 WK
I agree- I had almost the exact set of problems and the ignition switch solved them for good. Mine wad about $40 and I changed it in about 15 Mins in the driveway. Do a search and you will find a thread or two with step by steps
skrach77 is offline
post #9 of 12 Old 07-25-2012, 12:25 PM
ecollins7
2006 WK
I picked mine up for 25 from a local parts store.
Try picking up a Haynes Manual for your truck, it will have step by step instructions, mine has saved me several trips to the dealer
post #10 of 12 Old 07-29-2012, 10:17 AM Thread Starter
Briceronii
2006 WK
Thanks everyone
post #11 of 12 Old 11-08-2012, 01:14 PM
Helicop88
2007 WK
When you guys say the ignition switch is the problem is it the actual key'ed ignition cylinder or just this
http://www.rockauto.com/catalog/more...781&cc=1434485
switch/solenoid part?
I have the same dash/ instrument cluster flickering issues and would hope this resolves it.
Thanks!
Helicop88 is offline
post #12 of 12 Old 11-08-2012, 07:50 PM
Shafer57
2006 WK
Thanks!
Ignition "Switch" and "Cylinder" are two different things. The cylinder will not effect your vehicle in anyway unless it doesn't turn. The ignition cylinder is what interacts with the switch.
Common confusion.
Shafer57 is offline
Dash lights flickering antielvis ZJ Grand Cherokee Forum 11 06-26-2014 02:02 PM
Flickering Dash Lights Cutch ZJ Grand Cherokee Forum 3 01-07-2011 11:16 AM
flickering dash lights JD37055 ZJ Grand Cherokee Forum 11 11-08-2010 09:59 AM
Dash Lights Flickering Jones ZJ Grand Cherokee Forum 19 09-13-2010 09:23 AM
05 GC flickering dash lights tednelson83 WK Grand Cherokee & XK Commander Forum 2 02-11-2007 11:53 AM
