Dash Lights Flickering - Dimmer Problem on WK - Page 2 - JeepForum.com
post #16 of 55 Old 10-27-2010, 07:09 AM
powerhawk
Hello all, new to the forum. I was wondering when you folks are talking about the dash lights, are you also speaking of all the idiot lights as well. What I mean is all those lights that come one when you first start the vehicle. Seat belt, tpms, park brake, EBS and the rest of them. I have an 06Grand Cherokee laredo. This problem has been intermitent for a while, but becoming more frequent as of late.
powerhawk is offline
post #17 of 55 Old 10-27-2010, 11:56 AM
ameline
The flickering idiot lights is almost always due to a faulty ignition key switch. It's a $40 part that takes 30 minutes to replace.
ameline is offline
post #18 of 55 Old 10-28-2010, 08:15 AM
powerhawk
Excellant, thanks for the info. I will look into it.
post #19 of 55 Old 12-22-2010, 11:14 AM
TJ9999
Originally Posted by b0ogeyman View Post
That is interesting. I have the same exact problem on my 06 overland, the cluster and the nav unit flicker and dim whenever I have the setting on bright, but if i set it like half way down then it doesn't flicker anymore!
Same problem here on my 2005 WK Hemi. But it doesnt happen every time, it's pretty very irregular.
I guess I will change the light switch as suggested by Merlin when it gets worse. Thanks for the advice!
*** 2004 TJ Rubicon 4.7L Stroker / 42RLE / NV241 / 3" lift / 34" tires ***
TJ9999 is offline
post #20 of 55 Old 12-22-2010, 12:44 PM
lll2for3lll
2005 WK
Same problem here too. But it doesn't happen often.
lll2for3lll is offline
post #21 of 55 Old 12-24-2010, 11:19 AM
2005GRANDONE
2005 WK
my dash and hvac backlighting flashes ive isolated it to be the turn signal headlight switch when they start flashing i wiggle it and they stop not a big deal to me though but i will replace if it becomes more of an issue and ive got 62000 miles been doing it since 35000
05 laredo, 4.7 V8, H.O. cams, fastman t.b. OME hd 3", Rustys .5 spacers, bilstein 5150 rear, yukon spider & side gears, superchips flashpaq, 33x12.50x17 nitto mud grapplers on black moabs, 1.5 spidertrax wheel spacers, flowmaster 40 series, K&N cai, Mopar gas tank, T.C & engine skid plates, riddler diff cover, removed sway bar on front.
Jks quicker disconnects for sale pm me
2005GRANDONE is offline
post #22 of 55 Old 07-10-2011, 07:33 PM
bmuhlbach
I did my multifuction switch today super easy to do three torqs screws hold the cover then 2 screws hold the switch on.10 minute job.I also installed a new ignition switch this one took about 1 hour to do.pull trim piece around the ignition switch and there are 2 screws pull the trim around the cluster there is 1 screw to drop the switch down and discennect wires and cable wire to get the switch out then there is two tabs to hold in to seperate the switch and the rest of ignition
http://www.wkjeeps.com/interior_trim.htm#STEERING
bmuhlbach is offline
post #23 of 55 Old 12-27-2011, 11:46 PM
Georgia_Jeep
2005 WK
hey i have the dash light flickering issue but also sometimes my jeep wont start even tough the lights, radio and, ac all work if you add a little juice it starts dealer cant figure it out also my low tire light flashes for no reason dealer couldn't figure that one out either what do you guys think? i do know the clock spring is bad.
2005 Red Jeep Grand Cherokee Laredo 4x4 3.7L V6 QT-1
Mods:
Aux Lights, C.B. Radio, HID's
Georgia_Jeep is offline
post #24 of 55 Old 12-27-2011, 11:51 PM
cherrybomb05
2010 JK Wrangler
Probably the battery is going. The tire light flashes because of the cold.
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #25 of 55 Old 12-28-2011, 12:18 AM
Georgia_Jeep
2005 WK
battery is new (replaced it when it started happening) and the tire light comes on all year round but thanks for the reply
Mods:
post #26 of 55 Old 03-23-2012, 09:36 PM
Georgia_Jeep
2005 WK
driving 2night my dash lights were flashing like crazy i think even my head lights were doing it I tried lowering the dimmer settings but it kept flashing. what do you guys think it will cost to repair the ignition switch and dimmer from the dealer?
Mods:
post #27 of 55 Old 03-23-2012, 10:33 PM
Budasac
2005 WK
I would start with the MFS (multi-function switch). You can easily replace it yourself. As someone stated above, it's a ten minute job. Depending on what options you have (fogs/auto-headlights) it costs between $50 and $120.
Budasac is online now
post #28 of 55 Old 03-23-2012, 10:35 PM
kllshadow
2006 WK
Georgia I would start with just the multimillion switch because its a quick easy thing to change. It only takes about 10-20 mins to change so the dealership shouldn't charge to much but you can easily save the labor by changing it yourself its only like 5 screws.
I was out of town one day and saw a Wk going down the road with its headlights blinking and said to my wife what the hell is that idiot doing. Then on my way back home mine started doing it I replaced the multifunction switch and it never happened again.
kllshadow is offline
post #29 of 55 Old 03-23-2012, 11:46 PM
Georgia_Jeep
2005 WK
ok thanks for the help it also is having another electrical issue i noticed after i posted, the air bag off light only comes on when someone sits in the front seat otherwise its off.
Mods:
post #30 of 55 Old 03-24-2012, 01:01 AM
kllshadow
2006 WK
Not sure but I think passenger air bags are weight activated to keep them from going off with kids in the front seat.
Dash lights flickering antielvis ZJ Grand Cherokee Forum 11 06-26-2014 03:02 PM
Dash lights flickering? Easy Free Fix! boilinsrt ZJ Grand Cherokee Forum 0 10-01-2008 02:25 PM
05 GC flickering dash lights tednelson83 WK Grand Cherokee & XK Commander Forum 2 02-11-2007 12:53 PM
Console dimmer switch flickering gourdman2 ZJ Grand Cherokee Forum 1 05-23-2005 07:08 PM
Dash lights flickering? TOM380 ZJ Grand Cherokee Forum 5 06-26-2003 10:47 PM
