Dash Lights Flickering - Dimmer Problem on WK - JeepForum.com
post #1 of 55 Old 06-14-2009, 06:39 PM Thread Starter
Marc4885
2006 WK
I have seen a lot of posts in the ZJ & WJ Forum related to this type of problem but I can't seem to find anything for the WK.
I have a 2006 GC Laredo and the Instrument cluster lights up on the dash flicker constantly if the dimmer is set to anything higher than about halfway. When the dimmer is turned down low it does not flicker but then everything is barely lit up. The dealer has been worthless on offering a solution and because it is out of warranty wants a bunch of money to think about figuring it out.
This problem has been going on for months and It is driving me absolutely nuts. Has anybody else had this problem with their WK? And if so what is the fix?
Marc4885 is offline
post #2 of 55 Old 06-14-2009, 06:56 PM
konarider94
2005 WK
there is another newer thread a couple down that says somethign about christmas and they suggested replacing the ignition switch. check it out
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline
post #3 of 55 Old 06-14-2009, 07:21 PM Thread Starter
Marc4885
2006 WK
I have no issues with the exterior lights, and that problem seems a bit more severe than mine. My lights never go out they just flicker when the dimmer is set to a brighter setting. I saw that the older models had switches/modules that had known issues...still looking for responses here...thanks!
Marc4885 is offline
post #4 of 55 Old 06-14-2009, 07:56 PM
05gldwkjp
2005 WK
After a lot of reading, I have seen a lot of complaints about grand cherokee and commander owners having to replace their ignition switch for anything from dash lights flickering, to dash lights and exterior lights flickering, or their car cutting off during driving... Apparently they can cause a lot of electrical "gremlins" in a lot of newer cars.
So it may be worth it to look into.
05gldwkjp is offline
post #5 of 55 Old 01-12-2010, 01:39 PM
robtre
Old post ressurected! MY 2005 WK does this and the lights aroung the A/C cluster are completely out! Please bump for more info/help!
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline
post #6 of 55 Old 01-13-2010, 05:21 AM
merlinTec
merlinTec's Avatar
My rule is if the heater is also going off I replace the ignition switch, if it's just the dash light flicker I replace the stork.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #7 of 55 Old 01-16-2010, 09:38 PM
b0ogeyman
2006 WK
Regards,
Merlin
That is interesting. I have the same exact problem on my 06 overland, the cluster and the nav unit flicker and dim whenever I have the setting on bright, but if i set it like half way down then it doesn't flicker anymore!
What you said Merlin about the heat is interesting because after that flickering issue got worse (it happens more frequently) i noticed that when i set my heat on AUTO the heat get directed everywhere but on my front dashboard vents, however if i turn the setting to the front vents they work just fine. If it's summer and i have my air conditioner on AUTO the cold air get distributed through all ( bottom, defrost, and front vents).
Do you think both problems related? and that changing my ignition switch could solve the problem?
Thanks.
b0ogeyman is offline
post #8 of 55 Old 01-17-2010, 02:47 PM
merlinTec
merlinTec's Avatar
Hi
No when I said heater I mean the blower motor itself.
post #9 of 55 Old 01-17-2010, 03:45 PM
b0ogeyman
2006 WK
Hi
oh ok thanks Merlin i suppose if the ignition switch isnt too expensive i prolly should give it a try it might fix it!
post #10 of 55 Old 07-26-2010, 06:30 PM
MRsandman1106
2005 WK
Same issue on my '05 WK. The radio lights and dash lights started flickering about a month ago. At times when I would turn the dimmer light all the way on, the interior lights wouldn't come on at all. Not all the time, just sporadically. I checked out the forum and a week ago replaced the ignition switch. This cured the problem...until today- more radio light and dash light flickering, and the radio light will not stay on the highest setting, so it's very hard to see it whatsoever. I called the dealer a week ago before I purchased the switch and installed it on my own, and they stated it could be a bad cell in the battery, the ignition switch, or the dimmer switch. So I had the battery tested at Autozone for free. Battery is fine. That's when I decided to replace the ignition switch. Now I'm at a loss and wonder if it's even worth replacing the dimmer since I suspect that doing so may not even solve the problem. I think in general there are electrical issues with this model and year GC. I've already replaced the blower motor module 3X. If anyone has any updates, please advise. Thanks for any info.
MRsandman1106 is offline
post #11 of 55 Old 07-27-2010, 12:06 PM
merlinTec
merlinTec's Avatar
I would replace the multi function switch like I said earlier.
Regards,
Merlin
post #12 of 55 Old 07-27-2010, 11:29 PM
bmuhlbach
how hard of a job is it to do the multi fuction switch?Do you have to pull the air bag and or steering wheel?
bmuhlbach is offline
post #13 of 55 Old 07-28-2010, 08:29 PM
MRsandman1106
2005 WK
Looks like it's pretty involved, and yes, you do have to pull the steering wheel.
post #14 of 55 Old 07-29-2010, 02:06 PM
merlinTec
merlinTec's Avatar
Really easy. remove the under and lower shoud. Then 2 screws and slide the switch out. No air bag removal.
post #15 of 55 Old 07-29-2010, 11:12 PM
bmuhlbach
thank you for the reply. If mine gets worse i'll be changeing it out.
Dash lights flickering antielvis ZJ Grand Cherokee Forum 11 06-26-2014 02:02 PM
Dash lights flickering? Easy Free Fix! boilinsrt ZJ Grand Cherokee Forum 0 10-01-2008 01:25 PM
05 GC flickering dash lights tednelson83 WK Grand Cherokee & XK Commander Forum 2 02-11-2007 11:53 AM
Console dimmer switch flickering gourdman2 ZJ Grand Cherokee Forum 1 05-23-2005 06:08 PM
Dash lights flickering? TOM380 ZJ Grand Cherokee Forum 5 06-26-2003 09:47 PM
