-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Dash Lights Flashed and now will not stary (http://www.jeepforum.com/forum/f67/dash-lights-flashed-now-will-not-stary-1380868/)
sajohnson05 06-13-2012 02:22 PM
My wife has a 2007 Jeep Grand Cherokee Laredo with 74,000 miles. Friday she was driving and the dash lights flashed on and off two times for her. They have not done this since. Today she drove to work and everything was fine and was leaving and now the Jeep will not turn over. The dash lights come on but that is it. I tried to jump it from my Cherokee but it didn't jump. Does anyone have any ideas? Also there was a tick i heard under the hood and also in the car. Was not sure where it was coming from. Going to take the battery to get it checked tonight.
Thanks
Budasac 06-13-2012 02:32 PM
It could be a number of things. Need more info. The two may not even be related. Could be a bad ground on the starter. Was that the first time the dash lights blinked? Faulty ignition switches are relatively common and typically cause the dash to go a little haywire. Dash and headlights as well as radio backlights blinking could also be your MFS (multi-function switch) going bad.
sajohnson05 06-13-2012 02:36 PM
That was the first time that had happened. I was waiting to see if it happened again before i replaced the ignition switch and it never did. Then today it just wouldn't start and then i tried to jump it and wouldn't turn over.
Budasac 06-13-2012 03:32 PM
I would test the battery and check the ground on the starter then go from there.
ecollins7 06-13-2012 03:36 PM
I had a tread about this about a week or 2 ago but mine was doing it every day. I took out the instrument cluster and made sure the three plugs in the back were plugged in good. Then I replaced the ignition switch. It hasn't happened since
sajohnson05 06-13-2012 05:42 PM
Update:
When I turn the key it comes up check gauges. Also I hear a clicking sound in the fuse box closest to the battery, not sure what this means. Still will not turn over
sajohnson05 06-13-2012 07:49 PM
Could it be as easy as the battery terminal needs to be cleaned even if it does not look corrosion has set in?
The time now is 01:10 AM.
