In-Dash Aux Input - Page 3 - JeepForum.com
 1Likes
post #31 of 45 Old 01-17-2013, 04:20 PM
jjt250
2007 WK
Originally Posted by scott6 View Post
Crap my site-wide password appears to have broke my hosting ability
Its not a dock really, its the "premium car kit" with a DIY holder.
Amazon Link
The car kit plugs into a 12v socket, and runs 1 cable the zune, and has a Line level AUX out on the plug. I installed a 12v socket into the center console and ran the AUX behind all dash, under the console into the center console compartment. I also added a switch that lets me change between powered with the ON, or powered always or off. It Helps when I get in and out alot so the zune just keeps playing, and I dont have to keep hitting play.
Here you go, I figured out how to do it on my Skydrive
Hey thanks Scott for the info, didn't see it till now. Do you have any more info on that car dock? I have a Zune HD that I haven't used in a year and it would be great to just keep in my car at all times.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #32 of 45 Old 01-18-2013, 09:52 AM
fgallardo
2005 WK
Hello, I have the REQ stereo with the 6 disc changer, steering wheel controls, uconnect. I would like to swap it out with a REF radio with the AUX port. I see some on ebay, but I was wondering if I purchase one will it work with the steering wheel controls and uconnect? Also are the REF radio with the AUX port single disc?
thanks
fgallardo is offline
post #33 of 45 Old 01-18-2013, 10:52 AM
jjt250
2007 WK
thanks
Everything should still work if you switch to the REF. You do lose 6 disc but gain aux, I believe. I have the REQ as well and I bought an iSimple from Amazon for about $80. It works great and I have aux and iPod connector.
jjt250 is offline
post #34 of 45 Old 01-18-2013, 11:10 AM
fgallardo
2005 WK
coolio! thanks
post #35 of 45 Old 01-19-2013, 10:51 AM
Rammer500
2014 JK Wrangler
I have a PAC audio input adapter and a RAQ radio if anyone is interested. The PAC adds two inputs to it. Here it is on their site. http://pac-audio.com/productDetails....&CategoryID=24. Willing to separate and will let go for a good price. PM me if your interested.
2014 Rubicon, 6 speed, Mopar 2" with Fox, 285's on Level 8 Punch Wheels
2015 Renegade Trailhawk
Rammer500 is offline
post #36 of 45 Old 01-19-2013, 02:47 PM
scott6
http://www.amazon.com/Zune-HD-Premiu...remium+car+kit
20$! I paid $70 each for the two I have.
Dock connector connects to the Zune, goes to 12v plug, 12v plug has a AUX out on it. (strong AUX too) Also has a USB charging USB port on the 12v plug
scott6 is offline
post #37 of 45 Old 01-19-2013, 05:51 PM
jjt250
2007 WK
Wow $70? Seems overpriced but at least it's cheaper now! I think I'll order one. I was talking about the actual dock that the Zune is in....where'd you pick that up? Or does that come with the car kit?
jjt250 is offline
post #38 of 45 Old 01-19-2013, 06:50 PM
scott6
Search amazon for Zune Dock. There are 3. One of them is a "HD" Dock specifically for the Zune HD that has HDMI out, and optical audio. As well as analog audio out. The other docks are for the older Zunes but they still work fine on the HD if you only want to output sound to something and there super cheap. Also the older 2 docks don't have the right fitting for the HD, but it fits in there just fine. I use 2nd gen square dock over the 1st gen puck shaped unit in various places in my house. I also have a HD dock in my living room that runs optical out to my receiver that way my Media center and TV don't need to be on to listen to music.
Also note that the docks don't have line level out like the "premium" car kit does. That means the volume on the Zune needs to be to be turned up to get solid signal. Where as a line level out (like the car kit has) it always full volume no matter what the device volume is set at. That helps so when you grab the zune and plug in headphones in it doesn't blow your ears out.
I also think the car kit sounds better than the Zune pluged straight into the AUX with the volume at max. It seems to have a stronger or amped output.
EDIT:
Here is the v2 dock for under $10: http://www.amazon.com/Zune-H6A-00001...ords=zune+dock
There is also a v2 dock sold as a AV kit, that comes with a remote. For me the remote did not work at all, then when I got my actual Zune HD dock for the living room all the dock remotes just started working through out the house. Its like the Zune needed the HD dock to activate the remote functions or something.
scott6 is offline
post #39 of 45 Old 01-27-2013, 08:23 AM
MarkyZ
2005 WK
You guys could also just watch the classifieds for radios that already have the AUX built in. I got mine off kijiji for $30. Guy swapped out the factory unit with an aftermarket and just wanted to get rid of it.
First Jeep:1998 Grand Cherokee ZJ Laredo 4.0 I6
Second Jeep: 1999 Grand Cherokee WJ Limited 4.0 I6
Current Jeep: 2005 Grand Cherokee WK Laredo 4.7 V8
MarkyZ is offline
post #40 of 45 Old 04-08-2015, 01:18 PM
waterhammer
2005 WK
Will this one work the same? I found one locally for $40
http://www.pac-audio.com/productDeta...&CategoryID=26
1987 MJ
1994 XJ -Former NAXJA Member (Gone now)
2005 silver WK #158 OME HD...etc...
2013 Pierce Velocity (Work Truck)
Support your local search and rescue...GET LOST!
waterhammer is offline
post #41 of 45 Old 12-03-2015, 07:37 AM
Tobeornottobe
2005 WK
When your soldering the RCA patch to aux does it matter which wire goes where ?
Tobeornottobe is offline
post #42 of 45 Old 12-05-2015, 09:17 AM Thread Starter
DustinInDFW
2005 WK
Yes, there is a R, L and Ground. Follow the instructions on the part you bought. On the radio shack 1/8" jack, pin 1 was ground, pin 2 was L and pin 3 was R.
DustinInDFW is offline
post #43 of 45 Old 12-06-2015, 09:52 AM
Tobeornottobe
2005 WK
Ok great thanks ,
post #44 of 45 Old 03-09-2016, 09:08 PM
DarthJeep
2005 WK
How did you get around the circuit board in the 'bar'? I would like to put my aux input in same spot, but I can't figure out how to get arounder the circuit board. Can I drill through it, carefully avoiding the connections?
DarthJeep is offline
post #45 of 45 Old 03-10-2016, 06:17 AM
Tobeornottobe
2005 WK
Low audio
I found one on Craig's list for 40.00 , swapped it ant the audio from external /aux is way lower then from if I have reg radio stations playing ??????
Any one want to buy ref radio ?
i just got a wj want some input 22remud ZJ Grand Cherokee Forum 12 02-03-2010 10:02 PM
need input jhram318 ZJ Grand Cherokee Forum 4 08-30-2008 07:08 PM
need some input Packy ZJ Grand Cherokee Forum 1 10-10-2006 07:53 PM
Need input on '96 JGC rfd499 ZJ Grand Cherokee Forum 4 04-12-2006 11:52 AM
I need your input moabster ZJ Grand Cherokee Forum 11 06-02-2003 06:06 PM
