CV axles, or inner tie rods - JeepForum.com
post #1 of 13 Old 02-27-2013, 03:00 PM Thread Starter
ca07wk
2007 WK
I have "the front end knock" and I'm not sure if its the CV axles or inner tie rods. At first I only noticed it when I was turning during acceleration, now I also get it when hard braking down hill. I'm starting to think its the CV axles over the inner tie rods. Anyone have any experience with the front end knock coming from the CV axles? BTW its a rather loud knock, if that makes a difference.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #2 of 13 Old 02-27-2013, 04:00 PM
LordEnki
2006 WK
Raise your front end and wiggle your wheels side to side to check for play in tie rod ends, inner or outer.
Bad cv half shafts will click on sharp low speed turns.
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #3 of 13 Old 02-27-2013, 04:15 PM Thread Starter
ca07wk
2007 WK
I did the wheel wiggle and there was no play, i dont hear a click either. its a loud pop, its unpredictable, it doesnt happen every time during a accelerated turn or downhill stop. Maybe lca ball joints? It almost feels like something is slipping back in place
ca07wk is offline
post #4 of 13 Old 02-27-2013, 04:39 PM
yzjwk
2005 WK
sounds like sway bar bushings or links to me .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #5 of 13 Old 02-27-2013, 04:57 PM
kennymo
Mine makes this pop sound but only when i turn the wheel at a dead stop. next step for me is to get the front wheels off the ground and try it.
kennymo is offline
post #6 of 13 Old 02-27-2013, 05:30 PM Thread Starter
ca07wk
2007 WK
The sway bar is disco'd right now and still makes the pop
ca07wk is offline
post #7 of 13 Old 02-27-2013, 07:18 PM
yzjwk
2005 WK
I just remembered ,when my inner tie rod was bad you could only see it if someone was turning the steering wheel while you looked at it . i don't think i could detect any movement in the tire .
There was something else i read on here about the rack and pinion making a simmilar noise esp on takeoff .bit of a stretch maybe.
you can check this thread out .http://www.jeepforum.com/forum/f67/t...d-pop-1421373/
good luck
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #8 of 13 Old 02-28-2013, 10:32 AM Thread Starter
ca07wk
2007 WK
I've tried the bolt thing, I cant get it to budge.
ca07wk is offline
post #9 of 13 Old 02-28-2013, 07:08 PM Thread Starter
ca07wk
2007 WK
Anyone else have a possible reason? I'm going to start with the inner tie rods for now, they aren't as price as the CV axles, and if that doesn't solve it maybe the Lca ball joints, then the CV axles.
ca07wk is offline
post #10 of 13 Old 03-01-2013, 08:48 AM
LordEnki
2006 WK
So you are just going to throw money at it? Why not just check if the rod ends are worn first, rather than replacing things until you get it right? How about taking it to an actual mechanic for diagnosis?
Good luck.
06 WK Limited
LordEnki is offline
post #11 of 13 Old 04-24-2015, 10:12 AM
fast916
2009 WK
So what did it turn out to be?
fast916 is offline
post #12 of 13 Old 04-24-2015, 10:22 AM
paroxysym
2007 WK
how seized is the bolt? id try to give that bolt another crack at it..
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #13 of 13 Old 04-24-2015, 10:46 AM
Jtav2012
2005 WK
Oh really? This actually happens to me. I'll have to check it out when I do my lift install.
Not-stock 2005 5.7L WK
Jtav2012 is offline
