Cruise control not working - JeepForum.com
post #1 of 9 Old 09-19-2017, 04:19 PM Thread Starter
MarcosLlamas
2008 WK
2008 jeep grand Cherokee v6
I'm moving the lever, bottoms and looks like the cruise control isn't connected or something in wrong some where
No lights
No codes
No check engine
Also I found this connector
Is: green / blue line & green brown
MarcosLlamas is offline
post #2 of 9 Old 09-19-2017, 04:25 PM
underscore
2007 WK
Silly question, did you push in the button on the end?
2007 WK CRD QDII OME MD OMG WTF BBQ
underscore is offline
post #3 of 9 Old 09-19-2017, 04:28 PM Thread Starter
MarcosLlamas
2008 WK
Yes, but nothing, no light in the panel
Not setting
post #4 of 9 Old 09-19-2017, 07:49 PM
jeepstercanada
Scan for codes they will not always set the light. Also misfires will disable cruise
jeepstercanada is offline
post #5 of 9 Old 09-19-2017, 08:02 PM
azzkicker
2007 WK
That connector doesn't look like something a cruise control would use (too big, and not enough wires). I would think it would be very fine wires or one of those circuit board looking tapes, and I wouldn't think it could possibly do on/off/accel/decel/set with just 2 wires.
Did you look for a fuse? Mine looks different than yours (07 here), so I'm not sure how much help I can be. I just looked at my manual and didn't see a fuse for cruise control, so either I missed it or it's combined with something else.
A couple things, which I doubt your jeep cares about, but worth mentioning: I had a Lexus that would not set the cruise if the wipers were on high or if the transmission selector was limited to 3rd gear or so, or if you were going below about 30mph. I don't know if you were trying in any of those conditions anyway.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #6 of 9 Old 09-20-2017, 05:21 AM
Nejeep
Check the brake lights. If the switch on the brake pedal fails or is out of adjustment the cruise will not work.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #7 of 9 Old 09-26-2017, 01:09 AM Thread Starter
MarcosLlamas
2008 WK
https://youtu.be/grw9e0j5C3A
Here is a vídeo of the problem i have
Cruise is dead
Enviado desde mi LG-X180g mediante Tapatalk
post #8 of 9 Old 09-26-2017, 06:25 AM
azzkicker
2007 WK
Cruise is dead
You're kidding, right? I'm going to play along. Your cruise control doesn't work at zero mph? Yes it does. It keeps your vehicle at zero.
I've never owned a vehicle that would set the cruise at speeds below 25mph (usually a bit higher).
In your case, I believe the problem is a simple replacement part, easily found as there are about 6 billion on earth. Behind the steering wheel, you will find a large nut. Replace the nut behind the wheel, and your vehicle will be better off.
Sorry if I've made a mistake, or if you were simply being responsible and not taking video while driving, but I'm drunk and I have brain lesions. In any case, you responded to a post suggesting checking the brake lights to see if they are stuck on, and your response is a video of you sitting still and abusing the cruise button.
post #9 of 9 Old 09-26-2017, 05:24 PM Thread Starter
MarcosLlamas
2008 WK
Maybe is the cruise lever im the stering wheel
Isnt setting at high speed
No codes
No check engine
Car running OK
