cruise control fuse? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > cruise control fuse?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rock
Unread 04-13-2014, 07:33 PM   #1
OzzyNF
2005 WK
where is the fuse located? my cc light comes on in the dash but it won't set?
OzzyNF is offline   Reply With Quote
Unread 04-13-2014, 08:05 PM   #2
zeds_dead
2005 WK
What speed are you using it at?
Everyday, something new you want to do. Disease of Jeeps.
zeds_dead is offline   Reply With Quote
Unread 04-13-2014, 08:55 PM   #3
OzzyNF
2005 WK
bout 60 miles an hour
Unread 04-14-2014, 04:56 AM   #4
zeds_dead
2005 WK
Hmm. I don't know the fuse, I just know that some people try to use it under 30 and it doesn't work under 30. Have you tried wkjeeps.com? They have a fuse diagram on there, both of the ones in engine and in cabin.
Unread 04-14-2014, 08:46 AM   #5
JRLT
2010 WK
I was having troubles with mine till I started pushing the level three times to cancel/reset before setting the CC.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote
Unread 04-14-2014, 02:21 PM   #6
NotDamian
When I press mine, it turns on for about 3 seconds and disappears and I cant turn it back on unless I turn off and turn on my car.. then it still doesn't work
NotDamian is offline   Reply With Quote
Unread 04-15-2014, 07:19 AM   #7
justinmiller930
2005 WK
My cruise works intermittently as well. I'm not sure what's going on with it, I was hoping that the fuse was the problem.
justinmiller930 is offline   Reply With Quote
Unread 04-15-2014, 09:30 AM   #8
JeepCares
Here's some info from the 2005 WK Service Manual:
ROAD TEST
Perform a vehicle road test to verify reports of speed control system malfunction. The road test should include attention to the speedometer. Speedometer operation should be smooth and without flutter at all speeds.
Flutter in the speedometer indicates a problem which might cause surging in the speed control system. The cause of any speedometer problems should be corrected before proceeding. Refer to Instrument Cluster for speedometer diagnosis.
If a road test verifies a system problem and the speedometer operates properly, check for:
  • A Diagnostic Trouble Code (DTC). If a DTC exists, conduct tests per the Powertrain Diagnostic Procedures service manual.
  • A misadjusted brake (stop) lamp switch. This could also cause an intermittent problem.
  • Loose, damaged or corroded electrical connections at the servo (if used). Corrosion should be removed from electrical terminals and a light coating of Mopar ® MultiPurpose Grease, or equivalent, applied.
  • Leaking vacuum reservoir (if used).
  • Loose or leaking vacuum hoses or connections (if used).
  • Defective one-way vacuum check valve (if used).
  • Secure attachment of both ends of the speed control servo cable (if used).
  • Smooth operation of throttle linkage (if used) and throttle body air valve.
  • Failed speed control servo (if used). Do the servo vacuum test.
CAUTION: When test probing for voltage or continuity at electrical connectors, care must be taken not to damage connector, terminals or seals. If these components are damaged, intermittent or complete system failure may occur.
Lee
U.S. Top Care
Chrysler Group LLC
JeepCares is offline   Reply With Quote
Unread 04-15-2014, 10:32 PM   #9
OzzyNF
2005 WK
thanks..some helpful info there... however i wanna check the fuse first...does anyone know what fuse controls the cruise control?
