CRD Underhood Temps - JeepForum.com
post #1 of 14 Old 06-15-2009, 12:23 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
CRD Underhood Temps
I bought a dual probe temperature gauge and attached one on the manifold bracket with the probe itself hanging 1/4" off the metal. The other probe is attached just under the hose going to the Provent but directly over the exhaust pipe (about 12" of air between the hose and pipe.)
Preliminary temps at city speeds are as follows. All F
Ambient EGT Manifold Hose Speed
84 460 180 150 Idle
77 900 137 116 40
77 900 125 109 40
74 590 179 143 Idle
The temp at the manifold is less than 1/2 the EGT.
I doubt if the temp rises at all during regen since the DPF is below the passenger seat. I have another 500 miles to go before the next regen and will report the temps. I'll also try to get a probe right on the DPF to see how hot the exterior gets during regen.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #2 of 14 Old 06-15-2009, 12:37 PM
DarrylFlynn
2006 WK
The temp at the manifold is less than 1/2 the EGT..
I am not trying to be funny or sarcastic BUT Is there some point to this? What exactly are you hoping to achieve?
I have a CRD and perhaps naively thought that this type of work would have been done prior to the vehicle ever being manufactured. I am certainly unaware of any issue with the vehicle having unacceptable under bonnet temperatures and bearing in mind it is a vehicle designed to be used off road in arduous conditions, surely this has been done at the development stage.
Cheers Darryl
DarrylFlynn is offline
post #3 of 14 Old 06-15-2009, 03:37 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Cheers Darryl
Point
89 GW w/plow
wookiee is offline
post #4 of 14 Old 06-15-2009, 04:26 PM
DarrylFlynn
2006 WK
Well it looks like the response is about as useful as the project. Ho Humm!
post #5 of 14 Old 06-16-2009, 05:22 AM
Swayse
Post your findings, I for one would like to know. We never park our jeep when its regening, I'm sure its fine, but man there is some serious heat coming off of it. We reset our miles, and keep track of the regens, and make sure we drive a few miles after regen before we park it.
04 Jeep Rubicon
Swayse is offline
post #6 of 14 Old 06-17-2009, 10:54 AM
chadhargis
2008 WK
How can you tell when it goes into regen without an EGT gauge?
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline
post #7 of 14 Old 06-17-2009, 11:32 AM
Spider-One
2008 WK
In his sig it states he has the DashHawk with EGT gauge
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator
Spider-One is offline
post #8 of 14 Old 06-17-2009, 03:40 PM
chadhargis
2008 WK
Ah! Well, that would do it. I have a Scangauge, but it doesn't read EGT.
Chad Hargis
Nashville, TN
post #9 of 14 Old 07-30-2009, 09:27 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
More info to waste DarrylFlynn's precious time...
At 90 OAT..
The temps at idle are 160 and 150
At idle and regenerating it goes up to 265 and 196, hardly enough to cause a fire from oil vapor.
At 80 mph the temps are 124 and 77
89 GW w/plow
wookiee is offline
post #10 of 14 Old 07-30-2009, 09:29 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
The dashhawk also gives me cat1b1 temp reading which is the dpf, so you don't need the egt if you can read cat1b1
89 GW w/plow
wookiee is offline
post #11 of 14 Old 08-11-2013, 10:01 AM
gaiex
What are the max EGT temps when in heavy load?
Any one measured while in full throttle?
Thanks
gaiex is offline
post #12 of 14 Old 08-12-2013, 12:13 PM
jaje
2007 WK
All I know is the exhaust is hot enough to sting my feet from the tailpipe after a hard tow and I'm unhooking my trailer wearing flip flops!
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #13 of 14 Old 08-12-2013, 01:20 PM
Zlartibartfast
2007 WK
I'm reading cat1b1 via Torque - I have seen over 900F while the ambient temp was about 105F, cruising @ 65
I'd have to go back to my logs, but I think that's as hot as it ever got
Zlartibartfast is offline
post #14 of 14 Old 08-12-2013, 01:36 PM
gaiex
I asked because in stock form (with EGT probe before turbo) I'm reading 850C (~1560F) and don't even want to know how much with a tunned ECU!
Offcourse this is before turbo, but after, at the exhaust Cat's I'm reading only 650C (1200F) max
PS: garret says that turbo works with 830C (1526F) and new ball bearing turbo is up to 860C (1580F)
gaiex is offline
Normal A/C Temps? LaCeS OuT ZJ Grand Cherokee Forum 25 07-22-2008 08:49 AM
What do these temps mean? *Pics* Deschain ZJ Grand Cherokee Forum 10 01-03-2007 06:45 PM
Coolant Temps ryanp ZJ Grand Cherokee Forum 3 10-04-2006 08:04 AM
Are these temps normal? r0bby ZJ Grand Cherokee Forum 18 06-26-2005 08:51 PM
What temps are your WJ 4.7L running? BlaineWasHere ZJ Grand Cherokee Forum 17 06-08-2005 06:16 PM
