CRD transmission service - JeepForum.com
post #1 of 2 Old 01-21-2014, 03:33 PM Thread Starter
Hendrix9
2007 WK
I changed my transmission fluid and filter yesterday at 99,500 miles. The fluid didn't look all that bad, but when i dropped the pan(after sucking most of the fluid out from the top) the filter came down with it. The new filter didn't seem very secure when I pressed it onto position, either. Does the pan help hold it in place? It seemed kinda strange. It had a fair amount of metal on the magnet in the pan, but no more than I've seen changing other auto trannys.
I'm sure it'll be asked, I didn't have the correct dipstick so I did the match what you took out and put in the same amount back in tactic for the fluid. It was just over 4 quarts. Not ideal, but for the time being it'll be fine. I'm going to the dealer soon to have them diagnose what they think is going on with my transmission control/ erratic shift problems and I'll have them check the level.
Has anyone put an external screw on filter on these W5a580/nag1 transmissions?
TL;DR - What holds the trans filter in place and has anyone put an external filter on these?
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is online now
post #2 of 2 Old 01-21-2014, 05:58 PM
caddydaddy
2007 WK
I've seen aftermarket dipsticks sold. I'm not sure if they are as accurate as the OEM one though. http://www.ebay.com/itm/310742797808...84.m1423.l2649
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
193,000+ miles!
caddydaddy is offline
