CRD Transmission - JeepForum.com
post #1 of 21 Old 02-25-2010, 11:38 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
CRD Transmission
With 75,000 miles on it, I'll be changing the trans fluid & filter.
Which trans is on the CRD? NAG1?
I need to know in order to buy the dipstick & filter.
Is there a torque converter drain like on the Sprinters?
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #2 of 21 Old 02-25-2010, 01:21 PM
kreso
2010 WK
Without scan tool there is no change. You have to know exact oil temp and to fill proper quantity. Without you can overfill and by overfilling you can damage the tranny.
kreso is offline
post #3 of 21 Old 02-25-2010, 02:39 PM
CRD Dawg
2008 WK
I think I've read that this tranny is the same one that has been used in previous Benz products when they used a 5 speed auto (i.e. previous generation E, M classes)? It might be a good idea to have it done at a good independent Benz shop. On second thought, doesn't the SRT8 use the same tranny? If so, a Jeep dealer probably could handle it. What about one with a Sprinter franchise and trained techs?
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
CRD Dawg is offline
post #4 of 21 Old 02-25-2010, 02:43 PM
TonyVideo
TonyVideo's Avatar
2008 WK
My build sheet lists this transmission.
5-Spd Auto W5J400 Transmission
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #5 of 21 Old 02-25-2010, 06:09 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
My DashHawk will give the temp.
If I didn't have the DH, I'd just measure what drained out and put the same amount back in. As long as both were at the same temp.
I don't trust dealers and I trust trans shops even less.
89 GW w/plow
wookiee is offline
post #6 of 21 Old 02-25-2010, 06:55 PM
CRD Dawg
2008 WK
No doubt. I feel the same way. But a Sprinter trained tech should be able to properly manage a correct tranny flush.
CRD Dawg is offline
post #7 of 21 Old 02-25-2010, 08:23 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Ahh, I forgot about those build sheets, I'll order one up tonight, thanks.
Here's the link, if anyone asks.
http://www.jeep.com/wccsapp/universa...ull&category=U
89 GW w/plow
wookiee is offline
post #8 of 21 Old 02-25-2010, 08:43 PM
suzieque
2008 WK
this tsb may be of help, gives dipstick part number and readings at various temperatures.
http://www.wkjeeps.com/tsb/tsb_wk_2101105a.pdf
let us know how it goes!
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #9 of 21 Old 02-26-2010, 10:55 AM
SSF556
2008 WK
Suzieque....for a normal tranny oil change I do not think we need to do the flush 3 times?
SSF556 is offline
post #10 of 21 Old 02-26-2010, 03:33 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Correct, it says ...
This bulletin involves thoroughly flushing the NAG1 (W5A580) transmission of any water
contamination
I was going to change the filter, then do a flush, but it seems wherever I read about it, the majority say flushing is not a good idea.
So, I will change the oil & filter at 75,000 miles then change the oil only each year for the next two years. Sounds simple enough.
89 GW w/plow
wookiee is offline
post #11 of 21 Old 02-26-2010, 08:06 PM
no-blue-screen
2008 WK
I will be doing mine soon. I am not waiting...doing it at 30k. I plan to measure what I take out, put that same amount of new back in, drive it with the DH connected, and then check the fluid to the correct level. Only way you should be low on fluid if you do not have a leak is if you had a bad factory fill.
SOLD 2008 WK CRD Limited 4x4 - Jeep Green
no-blue-screen is offline
post #12 of 21 Old 02-26-2010, 08:50 PM
SSF556
2008 WK
I had mine done at 30k as well. The dealer did it. Unsure if they changed the filter. I will check tomorrow on the work order.
I will do it every 30k....Tranny is a weak point. Fresh fluid can only help.
SSF556 is offline
post #13 of 21 Old 02-27-2010, 01:09 PM
justa4banger
2007 WK
Hey wookie.... are you in a rush??? i have a tranny dipstick.... you can use if you want... and then mail it to me in Texas later on ...
let me know...
BTW the Dipstick i bought for a NAG1 off ebay for cheap (20.00 or so) will work, but it is a bit too long... i dunno why...but it works fine..
I might need ot consider changing my fluid i have a funny shift from 3rd to 4th, like it takes a momment for it to think and then shifts.. only happens at WOT.
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #14 of 21 Old 02-27-2010, 01:41 PM
Burtman88
1987 YJ Wrangler
I know i am just posting randomly in someones thread but check out these Pozers Get stuck exactly why i dont like hummers
Watch Double Hummer FAIL Video | Break.com
Burtman88 is offline
post #15 of 21 Old 02-28-2010, 04:55 AM
merlinTec
merlinTec's Avatar
let me know...
Even the dealer dipsticks are too long it's as they are. I also don't know why.
Wookiee just remember to have it in drive or reverse to get temp.
UK Chrysler Jeep Master Tec.
merlinTec is offline
Transmission Pan mlasms08 ZJ Grand Cherokee Forum 4 08-13-2008 02:36 PM
What transmission do I have? hitchhikingmike ZJ Grand Cherokee Forum 4 08-12-2008 06:23 PM
Is my transmission going bad? JeepHunter89 ZJ Grand Cherokee Forum 4 11-15-2006 08:18 AM
Transmission Upg for WJ EisBlade ZJ Grand Cherokee Forum 11 11-14-2006 10:52 AM
Transmission ?'s please help 4x4bill ZJ Grand Cherokee Forum 1 06-02-2004 05:19 PM
