CRD swirl motor resistor ???? - Page 8 - JeepForum.com
 1Likes
post #106 of 408 Old 09-18-2012, 10:14 AM
terrasmak
2007 WK
Originally Posted by Taquache View Post
This displaces oxygen thus reducing the effiency of the burn. It allows the motor to run better if you're not injecting oil vapor
Is this the same for a diesel vs gas engine
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #107 of 408 Old 09-18-2012, 10:22 AM
Taquache
2007 WK
Same, except most gasoline motors are naturally aspirated so in a diesel you're clogging a turbo and intercooler with gunk.
Taquache Motorsports
'07 Jeep Grand Cherokee 3.0L Mercedes CRD 2wd 110k miles and counting Murdered Out - Elephant Hose - Dashhawk - Powdercoat - "CAI"
'07 Fiat 2500 Dually Highly Modified
Taquache is offline
post #108 of 408 Old 09-18-2012, 10:41 AM
terrasmak
2007 WK
As you can see i cut out the part about the oil thru the intake track. More about the octane part, considering the difference between diesel and gas.
post #109 of 408 Old 09-18-2012, 11:16 AM
Taquache
2007 WK
Right, it's still putting oil vapor back into the cylinder instead of air, thus decreasing the effiency of the gasoline burn.
All of this is an emissions control which while reducing emissions also reduces MPG causing more fuel to be burnt creating more emissions per tank... I don't know if it reduces the emissions enough to compensate for having to burn more fuel.
Taquache is offline
post #110 of 408 Old 09-18-2012, 01:32 PM
terrasmak
2007 WK
You do know there is a big difference between gas and diesel right, hell a diesel has nothing to do with octane and can even run off thinned out oil.
post #111 of 408 Old 09-18-2012, 01:42 PM
tnadanzig
tnadanzig's Avatar
2007 WK
The tiny amount of CCV vapors going into the engine vs actual air is so small that I don't think it's worth even worrying about. This engine uses about 8-10 lb/min of air during normal 60 mph cruise that the amount of oil vapor sucked in is less than 0.5%. I don't think you could even measure the effiency gain on removing CCV vapor. Environmental conditions would have ten times more of an impact. The worst thing with CCV vapor is it mixing with the egr and gumming up.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #112 of 408 Old 09-18-2012, 01:44 PM
Taquache
2007 WK
LOL
Yes I know the differences. The burn factor is centane, diesel is also compression ignition rather than spark. None of this matters as we are talking about air when sending oil vapor back into the motor (gasious state not liquid)
You're asking about venting your crank back into the intake I said venting to the atmosphere is better on the motor because you're allowing 100% air through the intake instead of a reduced air volume due to the vapor displacing the air via a CCV in the intake.
Simple physics...
Taquache is offline
post #113 of 408 Old 09-18-2012, 01:49 PM
Taquache
2007 WK
I agree with this 100%
Will you see big gains... Probably not. Is it healthier overall for the life of the motor, yes I'd say so.
Taquache is offline
post #114 of 408 Old 09-19-2012, 05:04 AM
potamo
2005 WK
Agreed. Then, the resistor mod is a good alternative to a costly repair :-)
Next thing to do (EHM) when the electrical problems plaguing my JGC are fixed.
potamo is offline
post #115 of 408 Old 09-19-2012, 10:48 PM
Ciege
2007 WK
Looking forward to when the plugs are available. CEL came on today, resistor burned out. Cheap carbon film resistor from Radio Shack.
2007 WK Limited 3.0L CRD - CustomSpooling DPF delete - Swirl motor delete
Ciege is offline
post #116 of 408 Old 09-20-2012, 08:28 AM
Taquache
2007 WK
Do you think it was a cheap resistor or part of the environment that caused the failure?
I could use a part number of the swirl motor or if anyone has an old one they replaced does it have a brand on it or anything, that would really help in finding the correct plug to make this mod from.
Thanks
Taquache is offline
post #117 of 408 Old 09-20-2012, 06:45 PM
Tango.
Can you get that part # or even a swirl motor from your local Jeep dealer in Texas?
Tango. is offline
post #118 of 408 Old 09-20-2012, 07:25 PM
Taquache
2007 WK
I'll ask but electronics parts are non returnable and must be pre paid so that's a no go unless they have one on the shelf
Taquache is offline
post #119 of 408 Old 09-24-2012, 04:22 PM
Demeech
2008 WK
Hey guys, my dealer today said my swirl valve needs to be replaced. So vague with information. Not sure if this mod would help solve the problem or if im really looking at 4000 bucks to fix this crap. Can anyone help me?
Demeech is offline
post #120 of 408 Old 09-24-2012, 04:31 PM
Taquache
2007 WK
Yes this should fix your issue. Just by unplugging the swirl motor it should default to the open position and the resistor clears the CEL.
Can I get you to get the part number for the swirl motor from your dealer please. That will help me find the right connector to make these resistor plugs.
Taquache is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 381 04-10-2017 02:36 PM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 06:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 10:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 04:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 02:45 PM
