CRD swirl motor resistor ???? - Page 7 - JeepForum.com
 1Likes
post #91 of 390 Old 08-29-2012, 01:31 PM
SSF556
2008 WK
Add me for the resistor mod just in case....
Thanks
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #92 of 390 Old 08-30-2012, 05:44 PM
Taquache
2007 WK
User name #SDR/#IP
1. Taquache - 2/1
2. donk 316 - 1
3. jediknight - 1
4. Tango Tango - 1+
5. LJS8510 - 2
6. jaje - 1
7. Ciege - 2
8. Pixelcodex - 1
9. jediknight - 1/1
10. CGdieselGC - 1
11. Kolt-46 - 2/1
12. suzieque - 1
13. scootr29 - 1
List is up to date
Taquache Motorsports
'07 Jeep Grand Cherokee 3.0L Mercedes CRD 2wd 110k miles and counting Murdered Out - Elephant Hose - Dashhawk - Powdercoat - "CAI"
'07 Fiat 2500 Dually Highly Modified
Taquache is offline
post #93 of 390 Old 09-06-2012, 08:22 AM
sccobyste
resistor mod
Thanks
add me please
sccobyste is offline
post #94 of 390 Old 09-06-2012, 08:36 AM
gemiller
2008 WK
Add me for resistor plug and intake plug. You'll have to beat GDE to his DPF delete pipe(ill be buying his whole package tube/pipe) for me to buy resistor though, but the plug I'm interested in either way.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #95 of 390 Old 09-13-2012, 06:19 PM
Kolt-46
2008 WK
Any update on lead time for these?
Kolt-46 is offline
post #96 of 390 Old 09-13-2012, 07:07 PM
Tango.
2008 WK
It's been over a month and I haven't even see a proto type, or any previous work. So I guess we will see if he can make them or not soon?
Tango. is offline
post #97 of 390 Old 09-13-2012, 09:38 PM
Taquache
2007 WK
Patients please folks. We are trying to track down the correct plug so everything will fit, plug n play.
I need a little help from those who have replaced theirs. Did the unit have a manufacturer name on it?
The guy I'm working with went to Bosch because of the German motor but had no luck. After speaking with him today he's looking to Delphi to see what he can find, for those who DIY replaced the swirl motor do you have your old one?
Taquache is offline
post #98 of 390 Old 09-13-2012, 09:41 PM
Taquache
2007 WK
As far as previous work:
http://www.rollinsmokediesel.com/cat...ngineering.cfm
All made by Kurt Keifer, the guy I'm working on this with.
Google Shibby Engineering for more resources. I've personally installed his DPF delete sims on a few 6.7 Dodges.
Taquache is offline
post #99 of 390 Old 09-14-2012, 08:57 AM
Kolt-46
2008 WK
Kolt-46 is offline
post #100 of 390 Old 09-14-2012, 09:04 AM
jediknight
2008 WK
Originally Posted by Kolt-46
Those are female connector I think we need male connector to fit in the harness
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #101 of 390 Old 09-14-2012, 09:05 AM
Taquache
2007 WK
I'll pass that along. We need the female end of the swirl plug to make the resistor
Taquache is offline
post #102 of 390 Old 09-14-2012, 09:06 AM
Taquache
2007 WK
Yea what Jedi said. The plug it self will be female the pin side male yes
Taquache is offline
post #103 of 390 Old 09-18-2012, 08:20 AM
potamo
2005 WK
Count me in with the resistor mod.
If I do this mod, does make any sense to do the Elephant Hose Mod?
potamo is offline
post #104 of 390 Old 09-18-2012, 08:25 AM
pixelcodex
2007 WK
I have been wondering the same thing. I have a plug for the EH made by another forum member, but due to always adding competing priorities, have not had the time to get the hoses and the rest to do it.
pixelcodex is offline
post #105 of 390 Old 09-18-2012, 08:34 AM
Taquache
2007 WK
I would do it, if not you're still recirculating crank case vapor through your turbo, inter cooler, and in the intake. This displaces oxygen thus reducing the effiency of the burn. It allows the motor to run better if you're not injecting oil vapor
Taquache is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 375 09-11-2016 11:25 AM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 06:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 10:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 04:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 02:45 PM
