CRD swirl motor resistor ???? - Page 4 - JeepForum.com
 1Likes
post #46 of 408 Old 08-08-2012, 04:07 PM
jaje
2007 WK
Yeah - I'd rather pay a little more for a plug in device that looks professionally made than me using elec connectors and elec tape. Me and wiring are not the best combination.
jaje is offline
post #47 of 408 Old 08-08-2012, 05:28 PM
Taquache
2007 WK
cool I'll see what I can get done
Taquache Motorsports
'07 Jeep Grand Cherokee 3.0L Mercedes CRD 2wd 110k miles and counting Murdered Out - Elephant Hose - Dashhawk - Powdercoat - "CAI"
'07 Fiat 2500 Dually Highly Modified
Taquache is offline
post #48 of 408 Old 08-08-2012, 06:23 PM
Kauzuak
I'd be interested in one.
Kauzuak is offline
post #49 of 408 Old 08-08-2012, 07:00 PM
Taquache
2007 WK
Cool I'm doing some researching for us
Taquache is offline
post #50 of 408 Old 08-08-2012, 07:21 PM
suzieque
2008 WK
Count me in on a reasonably priced plug and play option too, test it once, then throw it in my 3.0L toolkit when I travel.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #51 of 408 Old 08-08-2012, 07:51 PM
gemiller
2008 WK
Add me on the to list.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #52 of 408 Old 08-09-2012, 07:20 AM
Taquache
2007 WK
So thats looking like roughly 5 people thus far a few wanting some extras, I've started to get this ball rolling so hopefully we can have results soon, the trick is tracking down the correct plug.
I'm also researching the EGR Delete resistor mod.
I'm not sure that one will be as easy to achieve with out a CEL
Taquache is offline
post #53 of 408 Old 08-09-2012, 07:49 AM
jediknight
2008 WK
What about just putting a block off plate on the EGR chanel ? Dont know if the o2 sensor will be influenced by that ?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #54 of 408 Old 08-09-2012, 08:18 AM
Tuco
Tuco's Avatar
2007 WK
I wish I had known about this 20 cent fix 2 years ago when I went through the repair myself. We have a new swirl motor and the EHM so I doubt we will have trouble again. But it sure is nice to know that this is an option.
I am somewhat surprised that there is no noticeable affect by removing the swirl function, but glad it is working for you all.
07 WK CRD Limited
Tuco is offline
post #55 of 408 Old 08-09-2012, 09:34 AM
tnadanzig
tnadanzig's Avatar
2007 WK
If you resistor the EGR you will get a CEL for low EGR flow and it could put you into limp mode. Some people it does some does not. You need to get the programming to remove that function, ie Custom Spooling.
Same as above.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #56 of 408 Old 08-09-2012, 12:12 PM
torqrise
2007 WK
Count me in for the resistor fix as well.
Even though I've got the improved seal, and a Provent catch can -- you never know. There could be other factors influencing the failure of the swirl motor -- like heat and 'age'...
torqrise is offline
post #57 of 408 Old 08-09-2012, 12:54 PM
jaje
2007 WK
My sentiments exactly - want it there for just in case as we use it for family vacations / towing so lots of miles. I also bought the extended warranty (top level) and will get all the little things fixed.
jaje is offline
post #58 of 408 Old 08-09-2012, 07:39 PM
Taquache
2007 WK
Thanks tnadanzig thats the same deal that happens on the 6.7 cummins.
You can unplug the EGR with no resistor on that truck and it'll run just fine but will have a CEL...
Taquache is offline
post #59 of 408 Old 08-09-2012, 08:28 PM
tnadanzig
tnadanzig's Avatar
2007 WK
Anyone have an extra resistor I can buy? Seems you can only buy it in bulk and only need one itself. I'd like to have this just in case as I use it to tow at least 2x a month.
If you want I have some extra resistors. Just shoot me a PM with your address.
No problem. Ya the computer on the OM642 is a little more touchy.
CB Engineering
CB-engineer.com
post #60 of 408 Old 08-10-2012, 08:10 AM
Taquache
2007 WK
What about an interest in the block off plugs, I can get some of them cut also if that is ok with ianrmz250
Originally Posted by CRD Dawg View Post
Don't bother with the second ridge to use a second o-ring. I thought, "if 1 is good, then 2 would be better", but the tolerances are so tight I ended up not even using the 2nd o-ring. Couldn't get it into the hole in the intake tube. I just put the 1 o-ring on towards the outer end of the plug, and hammered it in place. Here it is installed on my old intake tube. Also included the dimensions that "ianrmz250" came up with.
Taquache is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 381 04-10-2017 01:36 PM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 05:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 09:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 03:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 01:45 PM
