CRD swirl motor resistor ???? - Page 21 - JeepForum.com
 1Likes
post #301 of 407 Old 02-16-2014, 03:33 PM
smokydiesel
Bought a used Chrysler R320 CDI 4matic. Bought it very cheap, check engine light was on (P2015), engine had NO POWER (transmission would only downshift manually), liftgate would not lock, battery kept dying, windshield is cracked, SRS light comes on if the seat belt is not in a latch (front passenger seat) and 120K on the clock. I had a 07 dodge sprinter before (dead at 13K miles, gone) but I just love those German diesels. Looking for solutions I came upon this thread. I found the resistor in my home alarm panel. 4.7K (extra in a bag). Plugged it into the swirl motor connector and taped it up. Changed fuel filter, engine filters, oil, and cabin filters while at it. Also replaced tailgate latch, battery (2 hour job). This Chrysler R320 CDI is back to being very powerfull and transmission is downshifting again too. What a wonderful machine it is, as if almost made in Germany. This post got me on the road saving 4K dollars the dealer was asking for to repair, not to mention 4K dollars saved because it was being loaded onto a dealer auction truck (saved it just in time) and when I have time will get the intake replaced, somewhere arounf 200K miles. Thank you all!!
smokydiesel is offline
post #302 of 407 Old 03-25-2014, 05:22 PM
steann7167
swirl motor emulator
I got one of these swirl motor emulators and began to test after resetting my engine light almost instantly had another error code come up (p2008) which I have reset also as for performance seems hesitant on acceleration I am thinking that emulator is not the way to go I am looking to buy a new motor from Mercedes dealer as is cheaper than jeep dealer anyone agree / disagree any views welcome I also notice there is a snippet on this fault on Wikipedia personally I am tempted to report this on watchdog as this is not fun going into limp mode on a motorway due to their design flaw
steann7167 is offline
post #303 of 407 Old 03-25-2014, 05:47 PM
GDE
2005 KJ Liberty
A GDE tune will solve your issue at a more more reasonable price than dealer changing parts.
GDE is offline
post #304 of 407 Old 03-25-2014, 08:55 PM
Chirpz
Chirpz's Avatar
2007 WK
Hmm... if you are thinking about replacing your swirl motor I recommend you think again. It is a very difficult and fragile job. If you break your manifold linkage that connects to the swirl motor then you have to replace the manifolds. I have a step by step procedure for changing the swirl motor....but I recommend buying a GDE tune, or using the "resistor mod" instead. Then the swirl motor is no longer an issue.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #305 of 407 Old 03-26-2014, 03:44 PM
steann7167
as I posted I have put one of these emulators (resistor) btu now getting hesitation and lots of smoke then new error code of p2008
post #306 of 407 Old 05-07-2014, 08:35 PM
The_Admiral
2007 WK
Originally Posted by Taquache View Post
Just so I have a count to give to my buddy lets start a list of user name and how many plugs you'd like.
1. Taquache - 2
2. donk 316 - 1
3. jediknight - 1
4. Tango Tango - 1+
What ever became of this idea? Was anyone ever able to make a weatherproof plug?
The_Admiral is offline
post #307 of 407 Old 05-28-2014, 07:37 AM
C12H23
Extreme diesel performance
Carrys the plugs and resistor mod
I just picked up both, shipping was touch and
As with all online shopping. Parts arrived today.
No codes
C12H23 is offline
post #308 of 407 Old 05-28-2014, 08:53 AM
bersh
2008 WK
No codes
Kurt's price is a bit better on these - was $27 shipped for mine. I also ordered the aluminum plug while I was at it.
bersh is offline
post #309 of 407 Old 05-29-2014, 12:01 PM
dfw
I ordered the swirl delete resistor plug from Kurt. I am inclined to carry it in my CRD uninstalled to be used if the swirl motor fails, rather than install the plug immediately.
Question: if I install the plug after swirl motor failure will the plug installation alone get the engine out of limp mode, or must the error code also be cleared? I don't have a scanner, so this is a pretty important clarification. Thanks!
dfw is offline
post #310 of 407 Old 05-30-2014, 12:42 PM
C12H23
I have a obd2 and didn't have any codes,
I strongly believe in preventative maintenance.
I know it is a problem and will FAIL, so I wasn't about to wait for the inevitable
I did me fuel filter when I did the swirl motor delete.
Figured I was already in there.
- to answer your question, I believe you would have a code thrown and need to flash it.
( don't let fear or common sense get in the way )
C12H23 is offline
post #311 of 407 Old 05-31-2014, 12:41 PM
smokydiesel
Just un update, my benz (chrysler) is running great with the free resistor in the plug. Swirl motor completely disconnected. About 6K miles so far. Engine ran great right after the resistor installed before and after code reset. Not sure if benz ecu is different from jeep. Few days ago the engine died on the highway. After 2 minutes restarted and drove 40 miles. No codes other than fuel pressure too low, from cranking and no start. After digging, replaced crankshaft pos sensor and still no problem. Old Sensor was made in 2008. 5 minutes to replace under the car, l/h side where trans mates to engine. Bought sensor at stealer 60$.
post #312 of 407 Old 06-28-2014, 08:12 AM
PanzerVolk
2008 WK
Had the swirl motor go in my CRD. Dealer quoted $7500 to repair........just walked out.
Does anyone know where I could pick up the plug in the Edmonton area?
PanzerVolk is offline
post #313 of 407 Old 06-28-2014, 01:29 PM
08CanuckCRD
2008 WK
As far as I know, you'll have to order the plug online from Extreme Diesel, BUT any local electronics shop will carry the 4.7K 1/2 watt resistor - cost is about $0.35 each. I bought 3 and carry them in my glove box until I need one. Pick some up locally and install the resistor onto the 2 centre holes in the swirl motor plug (4-pin plug, you want the resistor jumping the centre 2 connectors). Wrap it up good with electrical tape, clear the codes and go!
It'll hold at least until the plug arrives in the mail. If you decide not to order the plug, I'd maybe look at some heat-resistant tape/shielding to help protect the resistor longer term.
Hope this helps you get your Jeep back on the road quickly!
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline
post #314 of 407 Old 06-29-2014, 08:20 PM
C12H23
Never had any codes after installing plug from XDP.
CERTIFIED RADIO WESTSIDE
17104-111 AVE, EDMONTON T5S 0A8
I picked up resistors there. 3 @ 5$?
Been a while. Probably cheaper?
C12H23 is offline
post #315 of 407 Old 06-29-2014, 10:29 PM
C12H23
*** I did mine before it went so I never had codes to deal with.
C12H23 is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 375 09-11-2016 10:25 AM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 05:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 09:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 03:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 01:45 PM
