CRD swirl motor resistor ???? - Page 2 - JeepForum.com
 1Likes
post #16 of 408 Old 06-15-2012, 10:34 AM
suzieque
2008 WK
Originally Posted by tdoster View Post
I am curious the legality of selling a connector for "Emergency Use Only"
One of my biggest fears is being a thousand miles away with the family and travel trailer in tow and having the swril motor go out and truck fall into limp mode while being out in the middle of nowhere. Think if nothing else will make a connector with instructions and soldered to spades and kept in the glove box for when it does happen.
yup, would be good to have a resistor sitting in the glove box with whatever other hand tools are needed to do the install just in case of a failure, you can make it home.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #17 of 408 Old 06-15-2012, 10:50 AM
NDSU_Bison
2014 WK
What are the disadvantages to doing this? I'm sure the swirl motor serves a purpose.
NDSU_Bison is offline
post #18 of 408 Old 06-15-2012, 12:22 PM
suzieque
2008 WK
nice little read/explaination
http://en.wikipedia.org/wiki/Swirl_flap
suzieque is offline
post #19 of 408 Old 06-18-2012, 07:47 PM Thread Starter
ylimits
2008 WK
So do I even need the swirl motor and the swirl flaps if I put the resistor in and if I put the resistor in can I take the motor and flaps out
ylimits is offline
post #20 of 408 Old 06-19-2012, 12:24 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by TurboDiesel View Post
hmm interesting..
curious to hear more
who is gonna be the guinnea pig?
I've had mine attached for a week, not too many miles yet.
Going on a 3,000 mile trip next week.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #21 of 408 Old 06-19-2012, 05:38 PM
TurboDiesel
2008 WK
Awesome, please keep us posted
ill have to find a local place to pick up a resistor
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #22 of 408 Old 06-20-2012, 12:17 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Here's one on my WK. I used a spade (fork) connector and cut off one side of the fork and soldered the resistor to the connectors. Then I taped it and put a tie wrap on it to prevent the tape from coming loose due to the engine temps.
89 GW w/plow
wookiee is offline
post #23 of 408 Old 06-20-2012, 05:45 PM
jediknight
2008 WK
How would qualify your performance and eco with the resistor added on top of the tune ?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #24 of 408 Old 06-25-2012, 06:26 PM
fred99x
2008 WK
Well, our 2008 GC is three months out of warranty and while my wife was driving to work, we got the dreaded P2015 code and the jeep is in limp mode. I have the new black seal as well as the Racor filter but after removing the turbo inlet duct, I see that there was still some oil leaking above the swirl motor. I'm going to buy the resistor tomorrow and hopefully it will work and get the jeep operational again.
fred99x is offline
post #25 of 408 Old 06-25-2012, 07:11 PM
waggoner5
Did mine today after losing major power coming up to the house. So far, runs great, no CEL. I have the In Motion tune as well and do not notice any difference in power with the resistor mod.
waggoner5 is offline
post #26 of 408 Old 06-25-2012, 08:59 PM
fred99x
2008 WK
Came across this document on how the Mercedes swirl motor functions. The Mercedes forum I found this on indicates that there should be no noticable difference in performance on whether the swirl flaps are open or closed. The Mercedes forum also indicated that using the resistor will fool the ecu into thinking that the motor is still connected. Since the swirl motor is disconnected, no fault codes can be generated so all should work as expected.
http://www.ms-motor-service.de/ximag...071_en_web.pdf
fred99x is offline
post #27 of 408 Old 06-26-2012, 01:05 PM
fred99x
2008 WK
Installed the 1 watt, 4.7K ohm resistor, cleared the fault code and the jeep is back up and running. Will be talking to the dealership to see if they will consider doing a repair.
fred99x is offline
post #28 of 408 Old 06-26-2012, 08:40 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I put 700 miles on it today, passed 10 vehicles, after a road works stoppage, at a sustained 100 mph and noticed no difference. Rough calc of mpg is same as before. Will put a calculator to it later. It did a regen at the usual 750 miles period.
89 GW w/plow
wookiee is offline
post #29 of 408 Old 06-28-2012, 08:22 AM
waggoner5
3 days with the resistor and still no issues. My swirl motor was needing replacement when this mod was done.
post #30 of 408 Old 07-03-2012, 10:50 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Just put 2,600 miles on it with the first two stops exactly the same as a month pre-resistor ago. Last month I didn't use the a/c, this trip it was on all the time. Drove just as hard and got 1 mpg better over 800 miles, so not statistically better, but definitely not worse. And it does seem to have better get up & go. Don't know why, don't care!
89 GW w/plow
wookiee is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 381 04-10-2017 01:36 PM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 05:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 09:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 03:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 01:45 PM
